Size of Engines
Old Oct 5, 2000 | 01:06 PM
knighthelm's Avatar
Size of Engines
What size of engines will bolt up to a 700R4 for a 2.8 v6 camaro?
I toasted my 2.8 and was wonder which engine I can use.
Old Oct 5, 2000 | 01:59 PM
RenoLB8's Avatar
2.8, 3.1, and 3.4, that's all folks.
-Reno
Old Oct 6, 2000 | 01:53 PM
knighthelm's Avatar
The next question is
if i use a 3.4 can I use all the parts off my 2.8 like the plenium, the injectors, the fuel pump? Also do I have to change the chip in the ECM or do I need a different ECM.
Old Oct 6, 2000 | 06:07 PM
RenoLB8's Avatar
If you use the 2.8's injection setup, then your stock computer will do. If you're going to try and get the 3.4's to work in your car, GOOD LUCK!
-Reno
toronto formula
Nov 10, 2015 06:17 AM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
knight72
Aug 10, 2015 09:32 PM
