Proper MAF de-screening question
Old Oct 9, 2000 | 04:44 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
last time i did this, i ended up having to buy a new MAF...and their not cheap. Whats the "proper" way to take out the screen? I noticed a quite LARGE difference from screen to no screen and back..and no screen is much better.... anyone?
Old Oct 9, 2000 | 05:32 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i did it on mine with a a hook made from a cut up metal coat hanger and a big screw driver, use the screwdriver to carefully puch a hole thru the screen and use the "hook" to pull the screen out being careful not to touch the elsectionics under the screen.. note on some v6 firebirds (i forget with which motors) youll pull a SES light after punching it out, this is because the bend that is in that intake tube in front of the MAF the reason for this being is in this setup that screen straightens airflow up so it passes thru the center of the MAF properly.. if you get the code, just try taking that bend out of the intake tube...
Old Oct 9, 2000 | 06:23 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Before u even do this, read Vader's response to my question about modding the MAF here, Take this link: https://www.thirdgen.org/messageforu...ML/001579.html
What he says really, is that only a heavily modded 350 would benefit from this.
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROC-ZTWENTYGR8 (edited October 09, 2000).]
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
