Speed density whatsis HELP!
Old Oct 17, 2000 | 05:04 PM
87 Firebird's Avatar
I took my bird into the dealer today to get some work done on it i.e. help with performance and idle issues. The main mech told me that I should get a speed density chip put in my car. He said some stuff about the MAF was chog in them so they went to speed density or something like that. help me out here. Will a chip really help me out here? I'm thinking of getting a performance chip anyhow, so I'm thinking hey, why not kill two turds with one stone! Thanks.
Kevin
87 Firebird 2.8 w/!MAF/!CAT/Cold air/Bosch Platinum +4/Neihoff Platinum
Wires/Blue Streak Cap+Rotor/Crazy Sound System/Crazy Driver/
Old Oct 17, 2000 | 06:14 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
wait..is ur mechanic thinking of using the new chip to completely do awap with the MAF..? or...??
88 Firebird 2.8
MODS (either coming or on):
Flowmaster Cat Back, Random Technologies Cat, 3" intermediate pipe, 10.4 Taylor Race Wires, MSD Coil, MSD Ignition Module, B&M Shifter, Transgo Shift Kit, Cold Air Induction..Then peeling and cracking paint..
2"cowl hood
3.4 engine -new-
s/c'r then im done, maybe some no2...
Old Oct 17, 2000 | 07:21 PM
He told me that all I need is a new chip. It uses graphs to determine the proper air flow, rather than MAF. It's supposed to work better than using the MAF, because GM had some sort of problem with them and incorporated speed density instead of replacing every single MAF. All the MAF will do after the chip is put in is measure air temp. The chip will do the rest, IIRC
Old Oct 17, 2000 | 07:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Tell him to stop snorting crack. Stick with the MAF form of air measurement, it's more accurate than Speed Density, and can respond to engine mods better.
He is correct though, in one aspect. In fact, I just covered this little "tidbit" of information in a post in Tech/General engine, with a conversation with Vader. Look for the message titled "Of Scarlet somethings, air, and electricity". Aw hell here's the link:
https://www.thirdgen.org/messageforu...ML/002085.html
Besides, when you get your aftermarket chip, it'll convert you right back to MAF operation.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
$750 L98
Feb 1, 2025 02:25 PM
jrdturbo
Mar 31, 2016 02:58 PM
Giocio
Oct 1, 2015 12:20 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RGB2015
Sep 20, 2015 09:26 PM
