removed air box out of 3.1
Old Oct 11, 2000 | 01:25 PM
a*jones's Avatar
I completely removed my stock air box from my 3.1 yesterday. so i have something similar to a k&n open element. My boss at work that nows some what about cars said that removing the air box will cause my injectors to clog. is this true or did he miss understand me and think that i removed everything including the air filter itself?
a*jones (bandit II)
'92 Firebird MFI 3.1 V6
Vortex Muffler,
k&n filtercharger,
rapidfires,
B&M shift kit
'79 T/A graphics,
bushing less tranny mounts,
open element
Old Oct 11, 2000 | 05:11 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Ive had mine on and have had no problems with injectors if they do clog just get fuel imnjector cleaner. but it wouldnt clog the injectors the air filter has nothign to do with fuel injectors as far as i know
Old Oct 12, 2000 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, your friend probably thought you had no air filter at all. And I agree with FASTRS, I don't see how an injector would clog- they just spray fuel, no air.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 15, 2000 | 01:52 PM
Monkie's Avatar
Can you PLEASE tell me how you did take off the box!? Im trying to do it now but I cant seem to figure out how to. Thanks!!!!
Old Oct 16, 2000 | 01:21 PM
a*jones's Avatar
take the black plastic thing off like you where changing your air filter. take out that really long screw and remove the air filter. you should see some kind of sensor (PCV valve???) going into the side of the air box, disconnect the wires going to the sensor. then you should be able to pull the air box straight out. then take the senor out of the side of the air box and hook the sensor back up. then put just your air filter back in and put the long screw through the center of it and then tighten down the intake. i just laid that sensor thing beside my air filter. it's on a short wire so i'm not afraid of losing it. hope this helped!
a*jones (bandit II)
Vortex Muffler,
k&n filtercharger,
rapidfires,
B&M shift kit
'79 T/A graphics,
open element
Old Oct 16, 2000 | 04:15 PM
FAST RS's Avatar
If i remebr correctly its the IAT sensor PCV is on the driverside valve cover
Old Oct 16, 2000 | 08:30 PM
Monkie's Avatar
So you dont have to worry about the sensor?? If you leave it just hanging there it wont hurt anything?? If you can leave it hanging there then whats the point of having it? Thanks alot guys!
Old Oct 17, 2000 | 12:49 AM
FAST RS's Avatar
i herd if you drill 8 1 inch holes in your splashguard by the cold air intake you will get more HP is this true???
Old Oct 17, 2000 | 01:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Monkie, you're right, it can just hang. It's (technically called MAT for third gens) there to measure the temp of the incoming air. So as long as the sensor's near incoming air, it'll read accurately. If you tied it up near your exhaust pipes, well, that won't work well.
Old Oct 17, 2000 | 08:48 PM
Monkie's Avatar
TomP I did what you said and put the sensor more down so that it would read colder air resulting in better throttle response and I took the box off and after all this I took it out to see if I could tell a difference and I could tell a very good change. It really didnt feel THAT MUCH faster but I could feel a better feeling. Almost like the car felt better lol. Anyways thanks alot for the help!!!
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bryan623
Aug 10, 2015 11:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
