V6 fuel pressure
Old Oct 18, 2000 | 10:08 PM
jason86/2.8's Avatar
V6 fuel pressure
I was looking around on the site and saw that increasing the fuel pressure on a V8 from 42psi to 50 psi increased peak hp by about 15. I was wondering about the results it would have on the V6. Is the stock fp 42psi on the V6 too? And how would I go about upping the fp? Thanx in advance!
1986 Berlinetta, 2.8L, newly rebuilt 700R4, 3.42 Posi. 129,000 miles and counting.
Wins:
1996 Mustang
1994ish Olds Acheiva
Losses:
1999 Grand Am SE
1996ish Honda Accord (twice)
1990ish Vette (never should have been dumb enough to race a vette in the V6)
Old Oct 18, 2000 | 11:25 PM
JoeG-89RS's Avatar
Not an answer but I once read that our fuel pressure regulatros couldn't be replaced as they were rivited on the fuel rail. But I was in the local pullit yardand found a frame rail with torx screws on the regulator. What gives? Can we put adjustabe regulators on?
Old Oct 19, 2000 | 02:03 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I was thinking that exact same thing in class today i herd these 2 kids talkin about there truck and it was funny how thy r like ya a catback dosent do anything bla bla im jsut stinng there laffin to my self. But how would u be able to do that. And speaking of fuel Powerpullys And my msd 6AL made a big difference in gas milage ive gone from 220 miles per tank to 260 miles per tank and still have 2 gallons of gas left.
Old Oct 19, 2000 | 12:39 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
While the GM manual states that the v6 fuel pressure regulator is not servicable, according to someone I knew a while ago, it -is- replaceable, and the v8 TPI units can be put on.
The regulators are not riveted, they are attached using security screws, so called because a little pin sticks out of the center of each screw. These take a star-bit with a hole drilled in the center. You can either find a kit with those bits in it, or use a dremel to remove the center pin. I've heard of a hammer & punch being used to flatten the screws' pins, but that seems a bit harsh.
Yeah stock FP is 42, but that's at idle, and the computer can increase it/decrease it as it sees necessary.
I'll probably add an AFPR after I do headwork.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Oct 19, 2000 | 01:21 PM
RenoLB8's Avatar
If FP is computer copntrolled, couldn't a well programmed chip up it for you then? Also, I've seen AFPR's in the fierostore.com, so they must work on 2.8 MPFI's.
-Reno
Old Oct 19, 2000 | 03:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh, I goofed a little bit.. the regulator is vaccumed control. I know the computer has a hand in the final fuel pressure, though. Maybe by controlling how long the injectors are open for? Or controlling how long the fuel pump stays on?
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
