Mystery bracket. What does it do??
Old Feb 2, 2011 | 08:31 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
There is a bracket attached to the back of the passenger side head on my 3.1 V6. Sorry I didn't add a photo- it sticks up between the trans dipstick and the coil. It's end has a large hole it it.
It appears to do nothing but make it freaking impossible to get the damn valve cover off. Can I just chuck it??
Old Feb 2, 2011 | 08:54 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Mystery bracket. What does it do??
you can ditch it...its for lifting the engine in and out, however there are ecm grounds attached to it as well so youll have to take those off and re attach them back to the head
Old Feb 3, 2011 | 09:50 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Thanks, I will yank it off- but I will keep it handy for my 3.4 swap!!
Old Feb 3, 2011 | 02:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You could yank it... Or you could leave it in place and swap the valve cover stud for one of the short ones at the top of the cover. Only problem I've had getting said covers off is the wiper motor, and getting around that is easy once the long stud comes out (and it always does because the nut is stuck).
Old Feb 3, 2011 | 02:29 PM
Pillsbry10's Avatar
That would be better
Old Feb 3, 2011 | 06:04 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Couldn't get it out. Loosened 2 bolts, but there must be a 3rd back there. I just put my polished fiero valve covers on and they fit going on better than the originals did coming off, so problem solved! Just waiting on my injectors and I can fire this baby up, FINALLY!
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Gordonr1973
Sep 29, 2015 11:59 AM
armybyrd
Sep 26, 2015 03:37 PM
75bike
Sep 20, 2015 09:37 PM
camarohelp
Sep 12, 2015 05:45 PM
