2.8 motor help!
Old Nov 2, 2000 | 10:03 PM
killrog22's Avatar
2.8 motor help!
My 88 2.8 Camaro runs really rough. When timing is set to factory spec I get no power. Timing chain is new, EGR valve is new, tune up was done, and we even tryed Zmax. Does anyone have any suggestions.
Old Nov 3, 2000 | 07:56 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Clogged injector? Firing order messed up? Timing off? The timing was what had screwed up my friend's '86 2.8. Some jackass put a distributor in it and advanced the hell outta the timing.
Throw some injector cleaner in it and see what it does.
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm w/ Keyless entry
IROC tailights/tinted windows
Old Nov 3, 2000 | 01:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It could also be that the timing mark on the balancer has moved, due to a deteriorating balancer.
Verify this by bringing the #1 (front passenger side) cylinder to Top Dead Center. I usually make sure the engine's cold for this: I pull the coil wire off the ignition coil. I remove the #1 spark plug. I put a large phillip's head screwdriver gently into the #1 plug hole. Then I put a breaker bar on a socket, and turn the center bolt of the crankshaft pulley "clockwise" until the screwdriver stops raising.
WHen it stops rising, the balancer mark should be pointing to "0 degrees advance".
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Cleotiz
Jan 6, 2018 08:56 PM
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
E Rod
Aug 28, 2015 05:17 AM
Randomtask2
Aug 26, 2015 03:34 PM
