MPFI vs. TBI
Old Nov 25, 2000 | 01:45 AM
Ovrclck350's Avatar
MPFI vs. TBI
As a former owner of a TBI 2.8 Blazer and proud new owner of a 3.1MPFI 92 Firebird, I was just wondering what the difference was. I mean, I worked on my Blazer a lot (one of the reasons it's gone) so I know how the TBI works...but mechanically and perfomance-wise, what's the difference. I haven't been able to drive my bird a lot yet because it's in the body shop, but my mom used to own a 3.1MPFI Beretta...and it was pretty fast. I think it ran a 16.3 or 16.8, can't remember.....
DRIVE IT LIKE YOU STOLE IT!
Old Nov 25, 2000 | 07:50 AM
Brian K's Avatar
A TBI is just a carb with injector(s) well a MPFI has 1 injector per cylinder. MPFI is suspsed to make more power over TBI, be more economical, but in theory follows the same ideas as TBI...
Old Nov 25, 2000 | 04:52 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Basically, a TBI is nothing more than a computer-controlled carb (in its appearance and, more or less, its function.) Multi port uses intake runners with an injector at each end. MPFI is more accurate, and as Brian said, more powerful and fuel efficient. TBI is cheaper to produce and easier to fix...hence why GM used TBI on various engines for as long as it did!
To give you an idea of the power difference between TBI and MPFI stock, here are some numbers:
TBI 2.8 = 120hp, TBI 3.1 = 125hp
MPFI 2.8 = 135hp, MPFI 3.1 = 140hp
Port injection doesn't make a monumental difference, but it is a noticeable one.
Jason E
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires,coil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
JasonEE98 on AOL IM
Old Nov 25, 2000 | 07:28 PM
Macgyver's Avatar
I get 32 MPG with my TBI 305.
Coop got 37 once.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
