How to remove A/C??
Old Feb 20, 2011 | 11:39 PM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
How to remove A/C??
Hey I was thinking about removing the A/C in my 2.8 liter engine, but I wasn't sure if it was really worth the trouble, and if so how do I remove it, since there is only 1 belt...a lil confused..thanks!
Old Feb 20, 2011 | 11:46 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: How to remove A/C??
It's stupid easy. You can either buy a delete pulley for about $30, or reroute a smaller belt around the rest of the pulleys. The condenser, compressor, accumulator and such will just unbolt. 40 minute job if you have no idea what you're doing.
Doing a COMPLETE delete will take longer, and require a delete panel for the firewall. Those are about $100 on ebay.
Old Feb 20, 2011 | 11:48 PM
calgutie's Avatar
Car: 1984 Z28
...........okay but do you think its actually worth the hassle??will i actually gain HP?
Old Feb 20, 2011 | 11:53 PM
Car: 1991 Firebird
1. Is it broke? If you don't miss it, sure, toss it. It's not hard and does free up room under the hood.
2. Nope. No hp is lost with it, so there is no hp to gain with it removed.
Old Feb 20, 2011 | 11:54 PM
calgutie's Avatar
Car: 1984 Z28
ohhh........okay then in that case I guess ill just leave it then..
Old Feb 21, 2011 | 08:43 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
You won't gain any power, but you'll gain get-up-and-go... You'll lose weight in the front of the car getting rid of the A/C garbage. Only thing you need to make sure of if you're going to remove it is whether it's discharged or not because if you crack open one of the fittings and the system is charged, you'll end up freezing off one of your fingers or something. Not to mention that refrigerant isn't very good to breathe in.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Ironhead38
Sep 7, 2015 02:26 PM
85Special
Sep 3, 2015 04:21 PM
