How do I open the radiator drain petcock?
Old Feb 24, 2011 | 09:16 PM
84CAMARO28inFL's Avatar
Do i just take a plier and turn it and let it drain that way?
Old Feb 24, 2011 | 09:59 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: How do I open the radiator drain petcock?
What type do you have?
Plastic wing nut? Plastic bolt head? Brass bolt head? Aluminum?
First try to use your hand if it's a plastic wing nut style, turn counter-clock wise.
If you do use pliers on a plastic wing nut type, grasp the fattest part behind the wing, apply turning pressure evenly-- don't try to twist it like you're taking off lug nuts.
If it's a bolt head type, use the appropriate size box end wrench, again, not twisting like you're taking off lug nuts.
Pre-soak it with PB Blaster or WD40.
Old Feb 25, 2011 | 08:30 AM
Pocket's Avatar
Car: 91 Trans Am
Its a plastic wing nut, just use your fingers
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
ericjon262
Sep 11, 2015 06:07 PM
blackandblue02
Sep 10, 2015 08:19 PM
89 formula TPI
Sep 7, 2015 11:06 AM
