My new airbox
Old Dec 10, 2000 | 05:17 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
My new airbox
I got the airbox of a 86 camaro and allready took the splash guards out.. now would it hurt anything if i were to drill 5 1/2 inch holes in the bottom of the air boox also so it can suck in more air? woudl this do anything at all? or is there something better i can do. i dont wana do the ram air setup tho.
Old Dec 10, 2000 | 05:44 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
i cut the WHOLE bottom off. when you think about it....1)it never rains here, and 2)even when it does rain, water can't reach that spot easily.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Dec 10, 2000 | 07:19 PM
FAST RS's Avatar
i herd not to cut the bottom off and just drill holes in it... LAstnight at 3AM i oulndt sleep and decided to use some gasket sealer to seal it up becasue i cleand it out with a hose and the whole thing was leaking... i just cant wait to put it in... ALso did your hosue you got from kragen have the conector for your PCV from the valve cover to the throtlebody ???
Old Dec 10, 2000 | 08:47 PM
Engine: LH0 3.1L
ok, i left the hose from the TB as is. this intake was designed for cars with MAF sensors so there will be about a 4 inch gap that need to be filled. that's where i put the hose from kragen's.(BTW, the pcv valve is on the driver's side). i'm pissed about my ram air setup so i'm gonna hit the junkyard again and get another bottom half of the intake. also, i don't know if this setup flows better...i just think it looks better.
Dan
1990 3.1L RS
Linson
Oct 24, 2025 02:00 PM
Z28z
Dec 23, 2001 01:56 PM
F0xBody50
Dec 13, 2001 11:57 PM
TRAXION
Aftermarket Product Review
Oct 24, 2000 05:23 PM
theformula
Oct 10, 2000 09:49 PM
