EGR Valve
Old Dec 2, 2000 | 04:17 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
EGR Valve
I think my EGR valve went i keep gettin a code 32 and checked all the connectons and reset the computer and the SES light still comes on is there a way i can tell if its bad ofr sure??? also is there a way i can bypass it for a while til i get around to putting a new one in they run min of 220.00$$
Old Dec 2, 2000 | 05:21 PM
Mike Harvey's Avatar
This is the best and only way to tell if you have a bad EGR valve. Spray WD-40 at the base of the EGR valve while the car is running. If it sucks the WD-40 in then our EGR is leaking and bad. Quick and easy. Later bro
- Mike Harvey -
The '86 Firebird http://www.geocities.com/flash_point2002
Old Dec 3, 2000 | 04:04 AM
FAST RS's Avatar
what exactly does the EGR do and am i doin anydamage with the code 32??? also is there a way i can take out the EGR and put resistors int the connector til i can get a new one? I have the mney i just dont see the use in it really and dont wana spend the cash right now...
Old Dec 3, 2000 | 04:06 AM
FAST RS's Avatar
Oh ya do they sell any kind of high performance EGR valve ive seen some moded and the dude said he gaine like 5 HP buy cutting off some stem
Old Dec 4, 2000 | 12:59 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Nobody sells a hi-po EGR. EGR only activates at high-speed, low-rpm "cruising" conditions, when the car is warmed up. Therefore it doesn't affect HP when you floor the gas. and if you're cruising (low rpm) you wouldn't use the extra HP anyway. That whole "block off the EGR!" or "disconnected EGR" thing is a load of bull... the only way someone gets faster from that is if either (A) their EGR was stuck open and always working, or (B) they have a good imagination.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 4, 2000 | 02:30 PM
FAST RS's Avatar
I saw the thing on LS1. com i think it was a modifactation on there page
Old Dec 4, 2000 | 03:07 PM
FAST RS's Avatar
Does this sound like the asket i sprayed WD40 and saw bubbles forming in 2 corners were the gasket it is. So is this a bad gasket i was gonna buy some orange permatex and sue that around it to seal it off.. would that work and is that the problem.
Old Dec 5, 2000 | 01:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Could be, but which gasket did you put the sealer on? The EGR-to-exhaust-manifold gasket, or the EGR-tube-to-throttle-body one?
I ask because a leak on the EGR-to-manifold gasket wouldn't be "too" bad. Since EGR doesn't work all the time, you wouldn't notice a problem all the time. If the EGR is closed, a leak in that spot is "just" an exhaust leak... know what I mean?
But if the leak's at the EGR-to-TB gasket, the leak is always affecting the motor.
One thing I just noticed- code 32... that should come from the vacuum switch. The computer just knows if the EGR valve gets vacuum or not; it doesn't know if the EGR reacts to the vacuum or not. It could be a cracked vacuum hose- the computer activates EGR, then "sees" no vacuum because of the leak, so it sets an error code.
Oops, wait, is that an electronic EGR valve? Or is it vacuum operated (hose going to top)? If it's electronic, then ignore my previous paragraph- I don't know how the electronic units work with the computer.
Old Dec 5, 2000 | 02:31 PM
FAST RS's Avatar
its a Digial EGR... the ligt would aways come on when i wa passing soemone doin around 70 or getting off the freeway but the conector on it is shot to hell.. and they dont sell connectors for it and ive been to 6 boneyards yet to find one with a ditial EGR connector and when i looked at the seal i took off it was the one between the exhaust manafold and EGR at the base of it in 2 spots were i saw some small hoes at i saw carboon buildup on the outside and those were the 2 spots that were bubling with WD-40
Old Dec 5, 2000 | 11:10 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
The "EGR tube mod"...That is on LS1 motors and there is an EGR pipe that runs into the middle of the air stream behind the throttle body. You cut this off and get a gain....As far as 5hp, Hmmmm
TomP is right on the money here.....I love people saying they gained (insert # here) Horsepower by disconnecting the EGR.....Yeh right.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Dec 7, 2000 | 03:06 PM
Dr Ross's Avatar
I find EGR valves at the Pick U Part yard in Santa Paula, Ca for $4.00 each. You must find the same model number as your car.
Old Dec 7, 2000 | 03:10 PM
FAST RS's Avatar
DR ross were in westlkae do you live i live in simi vally like 5 mins away
Old Dec 7, 2000 | 03:28 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
when are you getting this code 32? how often? im guessing once in awhile driving at highway speeds, usually decellerating a bit?
Old Dec 7, 2000 | 09:21 PM
FAST RS's Avatar
i normaly get it when passing or decelerating... i took it to my friends shop today and he has a tool to hook up to the EGR well we get there and pop the hood the connector is out i know for a fact it was in this morning ive had a problem with the connector about a year ago but anyway he hooks it up EGR is fine the connector is corroded and the plastic is comming off of it so i need a new connector.. Were im gonna find one i dono ive gone to 7 bone yards still cant find it and to get a new one i need to buy a new EGR not gonna do that... But the thing i dont get when i check the connector and put it back on i still had the SES light on
Old Dec 8, 2000 | 01:05 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is this the connector on the wiring harness? You can find those at "big" auto parts stores, they're made by Motormite.
Old Dec 8, 2000 | 01:22 PM
FAST RS's Avatar
I checked Napa autozone pepboys and the GM dealership they didnt have the kind i needed also the thirdgen catalofg i have didnt have the connector it had all the connectors except the one i needed... hopefuly its not rainging tommorw so i can go to the boneyards again... any one ever feel sad when the go to the boneyard and see all the 3rdgens that will never see the streets again
Old Dec 9, 2000 | 04:50 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
ahh.. what i was getting at was the egr solenoid, but the connector being loose/corroded would do the same thing.. yeah i hate seeing fbods in the yard, a lot of cars with potential.. my one local yard, only have one fbody, a 84 2.8 maro.. pretty much everything missing off of it, i have taken.. so its pretty much my #1 donor..
Old Dec 11, 2000 | 01:13 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
FastRS, what does the connector look like? I found a 5-pin MAF connector for some people on the main tech board, and they swore the same thing you're saying (that it doesn't exist), maybe I can get lucky twice!
Are the pins on the connector large-ish and round and separate? (Looks like: o o o ) Or, are they small-ish, square, and all linked together? (Looks like ::::: )
Old Dec 11, 2000 | 02:30 PM
FAST RS's Avatar
Well i have the connector now i took 2 its a 4 pin connector
think of it as being a triangle and the back has 2 square conectors in it the front has one in it and in the middle it had one
gta892000
Aug 11, 2019 11:16 AM
92firebirdguy
Sep 1, 2016 07:53 AM
m00n420
Sep 11, 2015 02:39 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
