Question for tomp or others!
Old Dec 10, 2000 | 09:22 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
when i bought the flywheel it was off of an 89 camaro..yesterday i began trying (trying) to bolt up the clutch and pressure plate and bellhousing. I found out the 87 clutch and pressure plate didnt bolt due to different flywheel inner bolt designs and the old pressure plate was way bigger. no biggie went and bought a new clutch and pressure plate. when i got home i couldnt figure out how the new one bolted either?! tomorrow im going to take off the flywheel again and see if i can figure it out with the flywheel off. Any info on this? obviously they should work... oh not only that...does the bellhousing from 87 and 89 work? i looked at it yesterday and it seems it doesnt there is quite a bit of hang over. Did the bellhousings also change from 87-89 as the flywheel did in 88? Thanks
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS
Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box, Air Intake Temp Guage, Brushed Aluminum Hood Pins
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
Old Dec 11, 2000 | 01:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I don't know anything about manual trannies; but here's my guess at everything-
What about the different flywheel keeps it from fitting the motor? There are a few holes in the crankshaft; one is not a screw hole, it's a locating hole... does that help? As far as I knew, the bolt pattern on the end of the crank didn't change between 82-whenever!
Also, I know if you have the correct flywheel on wrong, the teeth will hit the engine.. if the flywheel is flipped so the other side faces away, the teeth won't hit.
I just checked the Centerforce Clutch website at http://www.centerforce.com - seems that they say the same stuff was used from 85-89. The disc size is 9 1/8", input is 1-14 (whatever that means), and the disc & clutch & throwout bearings have the same part #'s.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 11, 2000 | 03:57 PM
yea i thought the same thing on the flywheel but i called GM and the flywheel design was changed in 88 to a different design. hmm... i bought a new clutch so im going to try to put it in later..thx for ur help!
T5 swap
Next to buy:
Old Dec 12, 2000 | 09:28 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey thanks for the info on that '88 Flywheel... sorry I couldn't be of more help. Did they say what was changed? I think the crankshaft went from externally balanced in 1986 to internally balanced in 1987- so in 1987 (from my info) the balance weights were removed from the flywheel. But '88... ?
Old Dec 12, 2000 | 03:56 PM
yea the balancing was changed in 87, but the "official" change on the line up didnt come til 88
T5 swap
Next to buy:
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
