Trans Poly Mounts
Old Feb 26, 2011 | 05:52 PM
Firebird1990's Avatar
Car: 1987 Trans Am,1989 GTA
Engine: 5.0 Tuned Port Injection, 5.7 tpi
Transmission: 700r4, 700r4
Axle/Gears: 2:73 Posi, 3:27 Borg Warner 9 Bolt
Trans Poly Mounts
Only see applications for v8 firebird and camaros not 6s Will it work for my for my tranny(700r4)?
Old Feb 26, 2011 | 05:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Trans Poly Mounts
Welcome to TGO. You probably have that awful oil-filled mount, which to replace is very expensive. I'd suggest buying an OE one-piece cross member and using an OE rubber mount, which is around $7.00. More about mounts here:
https://www.thirdgen.org/forums/tran...ison-pics.html
If you don't have the oil-filled, one mentioned above should fit.
JamesC
Old Feb 26, 2011 | 06:06 PM
yeah ive gone through 2 rubber mounts in a year
Old Feb 26, 2011 | 06:08 PM
JamesC's Avatar
I couldn't take the vibration involved with poly or Prothane, so even though my car is highly modified, I went rubber. Anyway, good luck with your project.
JamesC
Old Feb 26, 2011 | 07:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Short answer is yes, the poly mount will work just fine. Long answer is that you need to find the oil leak that's poisoning the rubber mounts. I guarantee there is one. Unless you have a highly modified engine putting out gobs of torque, that mount should last longer than a year (my original lasted several and even through the trans swap before it crapped out). Oil destabilizes the rubber in the mounts (and everything else, which is one of many reasons why you don't use oil-based fluids in the brake system), making it softer and more prone to splitting. Plus, I've found the newer cheapo mounts are VERY cheaply made...
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 5, 2015 07:57 PM
