In regards to Monkie's cold air intake
Old Dec 11, 2000 | 06:55 PM
Mike Harvey's Avatar
Hey bro I went to Home Depot to look for some aluminum piping and couldn't find anything. The closest thing that I found was alminum flex piping which looks pretty cool. Would that work well for a cold air intake? And how much difference is there between those 2? I like your idea, let me and the rest of the guys know. Thanx
- Mike Harvey -
The '86 Firebird http://www.geocities.com/flash_point2002
Old Dec 11, 2000 | 08:07 PM
Monkie's Avatar
Yea thats what I used. The 3" aluminum air conditioner tube that you can twist around to make it go in different directions. I got a tube of that, then I got two 2 1/2"-3 1/2" I think hose clamps. So I took all that back home and put one end of the tube facing the filter and used a hose clamp and clamped it to the radiator hose (I think. Well, its that metal hose going to the radiator). Then I bent the aluminum tube to go down right next to the plastic flap thing that you hear scrape when you go out of a steep drive way. At first I took the tube and clamped it to the bar that they use when they tow your car away. But then I figured nah. So I clamped it to something under the car. Im sorry but I have NO idea what it is. If I were you I would get what I got and just go your own way. Im thinking about putting a funnel on the end of the tube maybe later to get even more air going in. But thats all I can tell ya. Wish I could get some pics for ya!
Old Dec 11, 2000 | 09:32 PM
Thanx Monkie. I'm still deciding on either to use the ABS plastic from Home Depot or the aluminum flex tube. The flex tube sounds so much nicer b/c it would be easier but I gotta dig into my car when it's not raining to see how I want to do this. Thanx bro.
- Mike Harvey -
Old Dec 12, 2000 | 12:13 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
if ur also referring to dryer hose..look at it..when u hit the gas it compresses the tube and chokes performance
Flowmaster 80 series, Random Technologies Cat, 3" intermediate pipe, SS
Hand Made Tips, 3 1/4" out, Accel 8.8 wires, MSD Coil, MSD Ignition Module,MSD 6A Box, Air Intake Temp Guage, Brushed Aluminum Hood Pins
Currently Working On:
T5 swap
Next to buy:
Slp dual cold air intake!
Old Dec 12, 2000 | 04:12 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Graeme, even the aluminum dryer hoses? They're somewhat difficult to crush with a hand; I don't think they'd collapse. I used an "air intake hose" from Pep Boys, it came in a big green box; anyway, it's a very thin rubber hose with a metal ring inside, similar to a coil (or a Slinky! Remember those?)- it makes it crushproof.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 12, 2000 | 05:20 PM
So what would be the best then? I like Brian K.'s setup w/ the PVC piping that he has. I am contemplating the ABS plastic pieces that I saw at Home Depot, would that work pretty damn good?
- Mike Harvey -
Old Dec 12, 2000 | 05:54 PM
i used the aluminum stuff and was idling it by hand in the engine bay, reved it the hole tube compressed and killed the motor..thats why i dont have ram air/cold air in my sig anymore..im going to be using the SLP intake instead..
T5 swap
Next to buy:
Old Dec 12, 2000 | 07:48 PM
Monkie's Avatar
Are you talking about running the aluminum piping straight to the TB or like I did? If you are talking about the way I did it then there is no way it can kill the engine.
Old Dec 12, 2000 | 09:49 PM
nope actually ran it right outta after the MAF with all the stock intake inplace except air box...revved it to approximately 2200 then i saw the aluminum de-coil in front of me and the engine died.... !
T5 swap
Next to buy:
Old Dec 13, 2000 | 02:44 PM
Monkie's Avatar
Wow, thats kinda weird! I wonder what caused that??? Well Ive had mine on for about a week now doing mods on it here and there and it seems to be running 100% fine. Oh and I did put the funnel on last night and it made alot of difference.
Old Dec 13, 2000 | 04:21 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i cant gaurentee home depot will have it, but am 98% sure lowes will have what you need.. i got some of that 3" aluminum ducting, ask for it.. its used for ac/heat ducting in your house, comes in a sheet and snaps together to form a pipe, that and in plumbing they have theese 3" rubber unions with hoseclamps attached, a employee should be able to know what i mean.. youll have to cut the tube to length and sttach it to the MAF with the union and put your filter on the other end.. i wrapped the pipe up with elecxtrical tape to make it look better and provide a better seal.. if you cant find the tube, use some 3" PVC piping.. you not only dont wanna use anything flexable such as bendable tubing, not only because it flexes too easily, but the ridges in it will cause air turbulance which will make you lose power...
Old Dec 13, 2000 | 08:21 PM
Monkie's Avatar
Ok I get where you are comming from with the ridges and air turbulance. But 1: it you do it right you will not loose power. I know I didnt. But Im sure if you didnt use flexable pipe you would gain more cause it would flow better. So how could I use that to where it comes from the airbox down to under the left side of the car (if you are looking at it from the front)??? Help and ideas would be welcome!!! Thanks!!!
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
91 CRX (dont ask me why he raced me)
2nd Gen Z28 (350) haha to you V8 guys!
1992 RS 305 TBI (good race)
More to come
Old Dec 14, 2000 | 12:18 AM
take out stock air box...run 3" pvc right from MAF using a sewer adapter. Relocate the charcoal canister about 2" closer to the back of the car. Run the pipe to the fender opening, drop an elbow, run the pipe down and hook up a K&N Conical..thats my plan or the slp intake
T5 swap
Next to buy:
My Site:
www.geocities.com/firebird89white
Old Dec 14, 2000 | 06:53 AM
Monkie's Avatar
Just a suggestion but do not take off the airbox. You will loose HP. When you do a cold air intake "forced air induction" it blows air at a rather fast rate. So if you take the airbox off the air just keeps going through the filter. You need the box on to catch the air. Just run it through the snorkle thing. ** this is only for 1991-92 Camaros. I think those are the only years with my type intake setup.
Old Dec 14, 2000 | 03:52 PM
yours is somewhat different than mine and thats why i can do it...i was even thinking of just relocating the stock air box somewhere else but nah..buy a 4.7ohm resistor and Fastrs's old k&N and im set
T5 swap
Next to buy:
My Site:
Old Dec 14, 2000 | 06:48 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
just like graeme said.. tho run it on the other side for a camaro since the batter is opposite than on the firebirds.. i totally relocated my charcoal canister, shortened lines and mounted it on the strut tower...
4.7 ohm resistor, that for doing away with the temp sensor? i remeber a post where engineboy mentioned the right resistance for a ls1's sensor.. dun remember what it was and what we would need for ours.. but if thats it, i may just try it..
Old Dec 14, 2000 | 07:48 PM
Monkie's Avatar
Ok I have been wondering this. I have heard from alot of people/places that its a good idea to run the tube into your fender....How is that gonna get ANY airflow??? I looked tonight and I couldnt see where the air would come in from. Give me some clues.
Old Dec 15, 2000 | 01:00 AM
with the airflow for the radiator
T5 swap
Next to buy:
My Site:
Old Dec 15, 2000 | 03:34 PM
Monkie's Avatar
Wouldnt that be warm air then???
1992 Camaro RS 3.1L
T5 Manual 5 speed
Cold/RAM air intake
Z-28 Exhaust
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
More to come
Old Dec 15, 2000 | 06:03 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
theres plenty of airflow inside that fender, once your past the inner fender cover its wide open.. also if you run it to where the charcoal canister was you could cut a 3" hole or so in that battery tray on that side and run a tube with a elbow in it for even more cool air.. my k&n hovers right where the charcoal canister would be before i moved it..
Old Dec 15, 2000 | 08:29 PM
Monkie's Avatar
Does it matter what year the car is or what model it is???? Thanks!
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
