Seafoaming it through the PCV valve
Old Mar 4, 2011 | 08:29 AM
84CAMARO28inFL's Avatar
Has anyone done this to their V6? I have.. a few times! Runs.. well...
Has anyone else done it, and how did it go? And did you use "Seafoam?" works very well.
I sprayed the living **** out of my carb again and well im gonna take it somewhere to get looked at since someone suspected i might have a "cracked rear bowl" for "occasional" gas leak and smell ?
Old Mar 4, 2011 | 02:12 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: Seafoaming it through the PCV valve
Never seafoamed through the PCV before, only the brake booster line. I suppose doing it through the PCV might help clean it out... But then again they're only like $5 to replace...
Old Mar 4, 2011 | 05:04 PM
Hmmmmm
Were you able to get your brake booster line back on with no issue? Mine on my Olds was somewhat stubborn... And it appears to have NEVER been removed
Was yours easy or almost impossible to pop back on and off? And did you use a screwdriver? or a penetrating lube?
Old Mar 4, 2011 | 11:40 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Yeah the line comes on and off no problem. Just pull it off the little plastic 90* elbow that does into the booster.
Old Mar 5, 2011 | 04:24 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
That puts it into your oil.....you have to change the oil shortly after doing that, best use of seafoam is to put it to intake vacuum so it cleans up the manifolds, valves, and pistons. If you want to clean up all the areas that get oiled, use transmission fluid, then change the oil, just make sure you don't overfill it.
Old Mar 5, 2011 | 07:59 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Normally with Seafoam I put 1/3 in the gas, 1/3 down the brake booster vacuum line into the intake (have to rev the motor a little as you pour it slowly because it will have a vacuum leak with the line off), and I pour the rest into the oil. I let the car warm up and then change the oil. My mother-in-law did not change her oil for 2 years or so in her Bonneville. The oil looked horrible. It smoked like crazy after I put seafoam in it. It then developed a valve cover gasket leak (probably broke up the gunk around it) so I replaced that also.
Old Mar 7, 2011 | 08:27 PM
baboony's Avatar
Car: 1987 sport C and C
Engine: 2.8L
Transmission: 700r4w/ B and M kit
Axle/Gears: stock
I thought the kind with the spray nozzle through the intake helped free some lost power.
gta892000
Aug 11, 2019 11:16 AM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
sandman92084
Sep 12, 2015 10:27 PM
rjcme
Sep 5, 2015 01:23 PM
