grrr ran out of gas, now no start
Car: 88 camaro rs
Engine: stock 2.8L V6
Transmission: stock
Axle/Gears: stock
well, my fuel gauge isnt accurate, and i ran out of gas. filled up and now she wont start, check fuel pump, can hear that running when u turn the key. engine turns over but doesnt fire, maybe firs once or twice but doesnt run.
what should i start checking?
Car: 1992 Firebird
Engine: 3.1l
Re: grrr ran out of gas, now no start
turn the key to the accessory and back off a few times. itll build up enough pressure to get the fuel back into the injectors. At least thats what I've done. otherwise, Im not sure
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
yea i tried that, and still nothing, possible fuel lined clogged?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Time for a new filter!
Trash in tank, tank run dry, trash sucked into filter, clogged filter.
Make sure you use two wrnches to take filter out so you don't break a fuel line, and spray the connections with PB Blaster first to help loosen.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thats what baffles me, not saying your wrong, but the fuel sock is ubar tiny holes in it. Yet filters still clogg.
pump probably burned up, still hums but the plastic parts inside don't pull gas now like before.
member its the gas that cools the pump and keeps it from dying, run low on gas allot, the FP will suffer.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
well yea, ill check the fuel filter and lines, see whats going on in there, then from there if nothing is clogged in there, ill check the pump. guess its all trial and error with these cars, but thats the fun part
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Most likely the fuel pump died, just because you can hear it kick on doesn't mean its still working right, been there done that.
Yes its true we have reports of some cars not starting until they get half a tank of geas in them while others will fire as soon as whatever miniscule amount you put in goes to engine.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok so what should i do in order? ex: first get fuel filter, and install fuel pressure tester?
Car: 1992 RS
Engine: Carbed 350
). Plus, the sock is to keep contaminates large enough to hurt the pump impeller out of the pump, has nothing to do with keeping contaminates out of the engine - where the filter filters out on a micron level. That's why the filters always clog.
Nothing to 'check' with a fuel filter - just replace it - like $10. Easiest cheapest thing to try first.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok so replaced fuel filter, now another problem, as i was about to start work on fuel filter replacement i noticed the line had a kink it from previous owner. after i installed the filter i turn the key to get the fuel pump to turn on and now the line after the filter where the kink was, is leaking BADLY. my question is can i replace the line with rubber fule line tubing?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I don't like to use allot, have used it to patch, might want to get a flaring tool or compression fittings and cut in a section of new line.
but if its leaking, rest might too, when I went to do my SFC soon as I touched mine they all started to leak.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
its leaking only where the kink is on the line, how much do u think it will cost to just fix the one spot, its near where the line turns to go towards the engine from fuel filter
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok repair fuel line, and car still not running, hear 1 or 2 fires and then battery dies
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
had a 85 v-6 had to replace the fuel pump after my friend ran it out of gas.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
yea thats what im thinking, like the engine sounds like it works up a lil bit of gas, then fires that off
What is the "Correct" Fuel Pump replacement procedure? Fuel Pump for this car costs $25 brand new lol
.. how to do it WITHOUT hacking exhaust nor fully removing gas tank ? (And how to save alll my gas!)
When I replaced my fuel pump, my 'sock' had a bunch of holes torn in it - and it literally fell apart in my hands - they deteriorate over time. If the fuel pump is over 2-3 years old, it's easily possible that the sock has rips/tears in it (if it's even still there at all
84 2.8l have a block mounted pump.
Does shop charge rip-off process for this repair if it is easily accessible? or is it "get it there STAT" and stop starving engine for fuel ?
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
ok was working on camaro, still not running, so far change fuel filter, distributer cap, boil, and plug wires.
engine is getting gas, plug was wet, spark plugs are sparking, and just broke up with gf so car is not jealous and i have all time for her.
i just dont know where to go next.HELP
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
use a shot of starting fluid, if it still won't even pop then the spark is bad.
If it will try to fire off it, bad fuel or timing.
Car: 88 camaro rs
Transmission: stock
Axle/Gears: stock
it tries to fire and i just put new gas in it yesterday, i just got it to fire 5 times in a row but no running
Engine: 3.8, 3.4
In a 1985 Jaguar XJ6 4.2 you can change the fuel pump in under a half hour with a screwdriver and thats it, having disconnected hte battery terminals. i enjoyed that and miss that car a lot.On the Camaro, the symptom is the same. Starting fluid, runs? That means its not getting fuel. Therefore, return Fuel Pump for another.
And yes, ive had fuel pumps be loud, as they come in different sizes.. ? But for the Camaro, thats likely whats going on, FP is defective, symptom is the same!
THEN prime it with the key. You only really need to do that once.
NufNuffZ28
Aug 14, 2015 09:12 AM
