Car broke down today, what could be wrong???
Old Dec 27, 2000 | 09:51 PM
Mike Harvey's Avatar
Well my damn accelerator got stuck to the floor & wouldn't let go so I had to turn the car off while it was rolling & then eventually able to stop it, but what could of caused this & how do I fix this. It is an '86 Firebird w/ the MPFI 2.8L. Thanx
- Mike Harvey -
1986 Firebird S/E
Old Dec 27, 2000 | 10:31 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Mine did the same thing, only I think the floor mats I put in got caught behind the accelerator. Check the spring on the throttle body. Look for things it may get stuck on or if it's broken. If nothing seems out of place, WD-40 the spring and the hinge points behind the accelerator. I hope this helps.
My only mod: Flowmaster 40 series
Old Dec 27, 2000 | 11:38 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
make sure you didn't just hit the cruise control button by accident, i know i've done that a couple times, and it's scared the crap out of me. Go ahead, and start the car, if the RPM's shoot way up, then turn it back off, and check the Throttle Position. With the hood open, check the Throttle response from in the car, see if the pedal will release from inside the car, if the pedel is up, but the throttle is open, there's probably a problem with the (lines that connect the throttle to the cable) but don't know what they're called. Also, you might want to spray some WD40 on your throttle, the little thingie that turns when you hit the loud pedal, see if that'll loosen things up.
Old Dec 28, 2000 | 03:59 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
On your air intake hose were it connects to the throtle body the clamp can get shifted down or moved so when u accelerate the lever will get cought behind it and not be able to let go and your stuck at a open throtle i had that happen 4 times in the past 1st was my faiult the rest was for letting my friend work on my car
Old Dec 29, 2000 | 02:34 AM
3.1 firebird's Avatar
look at the throttel blade on the trottle body before you start the car and make sure its not stuck wide open. Just look and see whats causing the blade to stay open. COuld be the balde getting stuck open because of gunk, or one of the cables are being pulled by the accelerator, or something else. Good luck.
Old Dec 29, 2000 | 06:26 AM
Thanx guys; it's all fixed now. It was explained a little bit on how I fixed it on the other thread about my compression testing results. Too lazy to retype it again.
- Mike Harvey -
1986 Firebird S/E
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
dhonda200
Aug 11, 2015 11:50 PM
novaderrik
Aug 10, 2015 12:44 PM
1nastygta
Aug 8, 2015 07:38 PM
