Engine Problem with 2.8
Car: 1983 Camaro Berlinetta
Engine: 2.8L Carb V6
Transmission: 5-Speed Manual
Axle/Gears: Stock
I have, to my dismay, a horrible problem with my engine. The symptoms are almost immediate stalling, incredibly rough idle (the car shakes uncontrollably), and the RPMs are extremely low. It is nearly impossible to give it any throttle at all, because it dies immediately. I looked this up, and I found that the carb was the problem, but I'm not so sure. The engine and transmission is going to undergo a full rebuild soon, but I want to see what the malfunction is before me and pops take it apart.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Engine Problem with 2.8
Remove the spark plugs and examine the color, and then do a compression test...
