belt tensioner
Engine: LH0 3.1L
belt tensioner
ok guys, i think i need a new tensioner. it's wobbling back and forth at idle. well, i'm too lazy to call up the part store so does anyone know how much it is??? it seems like it's one of those "it costs HOW much??!!!" parts.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Dan
1990 3.1L RS
From: First one out of liberty city, burn it to the ground
wow u are lazy!! j/k..
But..go to partsamerica.com or autozone.com and u can get a price like that
89 Firebird
2.8 V6 w/ t5 tranny (383 tpi t56 w/ ati 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
89 Firebird
My Site:
Engine: LH0 3.1L
well, i went to kragen's and it was only $34 plus tax. i hope this stops my voltage gauge from bouncing around. has anyone else had this problem??? sometimes the gauge is fine and sometimes it bounces in tune with the engine......coincedentally, sometimes my tensioner stays still and sometimes it wobbles back and forth.
Dan
1990 3.1L RS
Dan
1990 3.1L RS
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When my AC is on my belt tensinoer wobbles like a **** would this mean its bad????? it has a little wobble when its off.. and how hard are they to change
Car: 1986 Firebird
Engine: 2.8 V6
There are two arrows on a tensioner. These designate the "range" that tensioner can act in. One arrow shows the "max travel position", when there's no belt on the tensioner. This is where the tensioner has sprung out as far as it can go.
The other arrow shows the "tightest position", meaning that the tensioner is pressing tight against the belt. This is where the tensioner is being compressed as far as it can go.
If the tensioner is at the "max travel extreme", chances are that the belt has stretched too much and the tensioner is not doing anything! Your belt is flopping around- and yes, that means you should buy a new belt.
Tensioner check? With your old belt off, try to move your tensioner from it's "max travel" to it's "fully compressed" arrow. Very hard to do? Your tensioner's fine. Very easy, as if there's no spring? Replace it. Also, spin the tensioner by hand. If it makes really bad noises, the bearings are shot, and replace it.
FYI the arrow on the center tensioner "circle" should always be between the two arrows on the tensioner body.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
