Problems adjusting TV Cable...
Old Jan 13, 2001 | 01:09 PM
Sweet_85_Bird's Avatar
My "tang" to adjust my TV cable wont press in to move the cable housing up.What the problem?
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Jan 13, 2001 | 02:55 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
press the "D" very hard! with a screwdriver.
check here at Kevins https://www.thirdgen.org/messgboard/...ML/000145.html
www.marion-becker-nidda.de
91 Firebird 3.1
Modsynomax ultra flow stainless steel
Old Jan 13, 2001 | 03:03 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
try some WD 40 maybe it's corroded
Her is what you need to do..........on the throttle lever,you should have 3 cables hooked to it.1 is the throttle cable...2 is the cruise cable...3 is the tv cable.
The tv cable goes in the same direction as the throttle cable...towards the rear.
Follow these cables where they pass thru a bracket.On the otherside of this bracket you will find the adjuster.You may have to turn the cable to see the lever.It looks like a boxed in U(or D).Press this lever in(it is housed inside of a black plastic sleeve)while holding it in push the end of the cable(where you can see the groves)thru the bracket.Once it is in all the way let go of the lever.Now push your throttle lever all the way open.It is now adjusted.
Where you see the cable pass thru the bracket....that assembly the cable actually pass thru is what adjust the cable.
I wish I could explain it with more detail.You just need to get in there and look for it.
Just look at the throttle lever on your throttle body...follow each cable untill you find it.
91 Firebird 3.1
Old Jan 15, 2001 | 02:43 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
i wrote up a little article on it.. its in the tech section.. it is kinda hard to press in, i always used a big screwdrive or small wrench or something..
customblackbird
Aug 15, 2021 10:16 PM
Infested
May 22, 2018 11:56 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
db057
Sep 4, 2015 07:57 AM
