Ok, confirmed not imaginary issue, my Fuel line or ? IS leaking at the front. Can I..
Old Mar 14, 2011 | 01:15 PM
84CAMARO28inFL's Avatar
.. MAYBE.. do this myself? (I would take a photo, however i lost my camera. yes, lost it.) I will stick with this thread, too. I almost didnt post about it, but it IS a massive gas leak, and i elected to ask for advice, and weigh if i can do this myself. First time if so..
Car runs very well, even with the drip. Problem is, its WHOLLY unsafe right now (inside of car smells like gas, i have a puddle of 89-octane gasoline under the car) .. and im evaluating if i can do this myself, as i have virtually NO money, and a whole lot of time..
Basically, i confirmed it is dripping from where the line meets the filter. A nice, little upside-down "U" the line seems to take. I wish i could snap a photo. But, this explains the 1) wavy gas gauge readings, at least. Someone mentioned it could be the mechanical pump itself. I hope it is just the line. At least a pump costs $25, not like on fuel injected cars!
So, as tempted as i was to "just call someone" and have a money issue (i wont return the shop's call, they were booked up today and tomorrow they do good business thats good,) im debating as to how best to 1) change the fuel filter, and 2) get that line to stop leaking. if my gas gauge levels out after this, im sure im be better off. If not then iu have another issue. (Tank is almost on "E" now, de to leak. From full tank to that in two days, with "two trips" before i decided i shouldnt run the risk of blowing this beautiful car up.)
Thanks. (1984 Camaro, 2.8L Auto, carb'd, massive physical gas leak at the front and i can see the fuel filter and line laying on ground looking up at driver's side, perhaps even get to it..)
Thank you
Old Mar 15, 2011 | 12:04 PM
Re: Ok, confirmed not imaginary issue, my Fuel line or ? IS leaking at the front. Can
Ok, i got quoted $140 for 1.5 hrs labor and the part. Good or no?
Old Mar 15, 2011 | 12:13 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Not too bad, but high for what it is. A filter and line replacement should be like 5 minutes for a pro.
Do you have the jack stands and basic tools needed? If so, I'd give it a go. I'm a moron and I figured out how to change the fuel filter.
Got a cell phone with a camera? Take a pic and text it to your email, then upload on here....
Also, money for parts: when I was a broke-@$$ college student, I'd donate plasma. $40 for an hour of sitting on your butt watching movies.
Old Mar 15, 2011 | 07:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Fuel pump, fuel filter, fuel injection hose, and a couple hose clamps will fix that thing up nice.
Replacing the fuel pump is literally 2 bolts and a gasket (which you can make out of the leftover RTV I know you have) plus removing and reconnecting the fuel hoses/lines, and the fuel filter should be one fitting and a hose, or 2 fittings. Then you take some sort of a saw on the damaged line and cut out the bad portion to replace it with a piece of fuel injection hose and 2 clamps.
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
