Planning my rebuild...info appreciated
Old Jan 16, 2001 | 04:12 PM
87 Firebird's Avatar
So I've been looking into a rebuild of my 2.8 for a bit now, and here's what I've decided to (most likely) do. I firstly want to stroke the think out to a 3.1 What will I need to do that? I know a crank, and rods, but I'm fairly sure there was something else there. I'm gonna put some really groovy rings on, port out the heads a bit, and put in a performance cam and rockers. Now, what brands? I don't want to go insane expensive on the cam and rockers, either. At most, 250-300 US. What all else should I do while she's in pieces? I plan on repainting the motor while I'm there, also. What sort of hp can I hope for? Any other words of wisdom are muchly appreciated. Thanks.
87 Firebird 2.8 w/!MAF/!CAT/K&N Filter/Bosch Platinum +4/Neihoff Platinum
Wires/Blue Streak Cap+Rotor/Crazy Sound System/Crazy Driver/
Old Jan 16, 2001 | 04:20 PM
Brian K's Avatar
Look into a Crane 2030 Cam unless emmissions testing is strict in your area, because I have heard rumors they don't always pass.... If I were rebuilding 'my' wish list would be:
Crane 2030 Cam
1.52 Roller Tips
Double Roller Chain<-- Have
Ported Heads
Bored .30 over
Forged Pistons for NOS
Felpro Gasket set
High Flow Oil Pump
Clean up the rods casting marks
Shave the heads 1000th of an inch
Fast Chip from Ed Wright<--- Have
Power Pulleys
Dynomax Cat Back<--Have
MSD Wires
Accel Cap/Rotor
Accel HEI Module
MSD Coil<--- Have
MDS 6a Ignition Box (Have Accel)
Front End Urethane rebuild kit
Old Jan 26, 2001 | 07:48 AM
FBODY-ADDICT's Avatar
check this out 87 www.engine-parts.com/Online_catalog/Engines/gmv6conv/gm31.html
[This message has been edited by FBODY-ADDICT (edited January 26, 2001).]
BAMiller
Sep 14, 2015 06:38 PM
TheTraut88
Sep 11, 2015 05:16 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Fox118
Sep 1, 2015 04:07 PM
