rear end delay
Old Jan 22, 2001 | 11:08 PM
matlock's Avatar
Car: 89 GTA
rear end delay
I hope this isnt too big of a problem with my camaro. This only happenes when Im taking a corner.. half way around it I floor the gas its like its in neutral, then once im around the corner it starts to go. Is there a problem with the rear end? Actually the first few times I really hammered on it around a corner, I heard a clunk in the back and the same thing happened.. no power then it goes. Now theres no clunk and does the same thing. Hehe, Im not that rough on the car, was just booting around a bit.
Old Jan 22, 2001 | 11:28 PM
Red91Bird's Avatar
I am sure you have done this, but have you checked your tranny fluid level? from there the only other thing that can "disengauge" would be something in the rear end itself, and i have never heard of that happening to a rearend in corners only.
91 Firebird
3.1 w/
K&N filter, 160 stat, No TB heat, Direct Cold air, DynoMax CatBack, B&M MegaShifter, Performance Shift Kit,
Bosch platinum plugs,
7mm "stock" wires, Jensen CD330X Head unit, Jensen 120watt rear speakers
Stock front speakers,
0-30mph 4.25 Best 4.09
0-60mph 9.16 Best 9.09
Old Jan 23, 2001 | 02:50 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Are you sure it's acting like it's in neutral and not like the engine simply isn't getting fuel? Our fuel tanks are kinda flaky when aggressivly cornering with a low fuel level.. try with at least a half-full tank and it shouldn't do this anymore.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4
In search of new v8 engine & transmission
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers
Old Jan 23, 2001 | 07:30 AM
Ovrclck350's Avatar
A clunk? Mine kinda did the same thing when the transmission mount was broke. They're only $5 and easy to replace, so might as well check it.
92 Bird 3.1L Auto
Best $750 I ever spent....
DRIVE IT LIKE YOU STOLE IT!
Kills:
93 Mustang LX (Before Mods)
98 or 99 Dodge Stratus (tough one, edged out at 40)
92 Camaro RS 305 TPI
Close Calls
94 Grand Am 3.1 V6
92 Cavalier 3.1 V6
01 Porsche 911 Turbo (Had em till first gear)
Mods-Jet Stage 2 Performance Chip, Accel Cap/Rotor, Accel 8.8 MM Wires, Accell Coil, AC Delco Rapidfire Plugs, Dynomax Catback, K&N
AIM name OVRCLCK350
Old Jan 23, 2001 | 01:57 PM
jason86/2.8's Avatar
I floored my car pulling out of a parking space at school one time and I had that clunking noise. It didn't seem to come out of gear like you said, just the noise. And yeah our tanks are funny when low on fuel. I took a corner hard one time w/ only a gallon or so in the tank and the engine died while I was in the corner, but picked up again as soon as the car was straight. Scared the crap out of me though.
Red 1986 SC, 2.8L, rebuilt 700R4, 3.42 Posi, t-tops, 134K miles and counting, K&N air filters, hopefully more to come!
Old Jan 23, 2001 | 07:03 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
My clunking sound turned out to be a combo of tranny mount and broken intermediate pipe hangar. About these gas tanks, I had to hit the brakes hard to stop once, all the fuel came forward, and my car died. I think I know how you felt Jason!
My only mod: Flowmaster 40 series
Old Jan 25, 2001 | 01:59 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
About running out of gas i awlays end up running out at the gas station its cool tho ecasue inorder to move you have to floor the car and since the back end is so light wiht out gas big burnouts
Old Jan 26, 2001 | 11:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Guys, be careful with running too low, and I'm not going to talk about dirt in the tank, either. When a fuel pump runs dry (engine cuts out), the pump gets damaged. It might not damage itself much, but do it often enough, and it'll wear down.
Also, the pumps heat up, which can kill them. When the tank's got enough gas in it to cover the fuel pump, the fuel cools the pump. Ever since I replaced my pump, I try to never get under 1/4 tank. I used to drive around with the motor cutting out all the time...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
