2.8 coming out of storage
Old Jan 17, 2001 | 01:06 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
For about 2 years, I drove a 86 Camaro w/ the 2.8 MPFI v6. Last summer, I bought a 2000 Grand Am SE2. I took the Camaro off the road. While the weather was still warm, I would start it and let it run about 20 minutes once or twice a week. Once the weather got cold here in NY, I bought a cover and covered her up. So the car has not run since probably early November. Is there anything I should be worried about when I fire her up in the spring? (Besides a dead battery.) By the way, the car was losing little or no coolant or oil, and the tranny was rebuilt and has about 4k on it.
"Little girls play with ponies!"
Old Jan 17, 2001 | 01:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The valve seals might have hardened/cracked/dried up from lack of use. This would leave you with a harmless puff of blue smoke for every start-up.
You might also want to find a way to prime the oil pump with an electric drill; this will help get some oil back through the engine before you turn the key.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 17, 2001 | 01:59 PM
ONEFINE8T9's Avatar
i wouldnt worry to much about it. I barely drive my car in the summer and its in storage for the winter so i know how it is not to run ur car. I am always afraid of someone crakcing my baby up so i never drive it and if i do its at like 3 am. But back to ur question just make sure the battery is good and i might(might) wanna throw some fresh gas in it. U can acctually do that after u run the car its no big deal.
BTW where in ny u from???
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old Jan 17, 2001 | 02:19 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
So far I'm starting to feel better. I should have mentioned though that the car is stored covered OUTSIDE. Will this make any difference? And any ideas how to prime the oil pump?
To the guy who asked- I'm from Babylon, on Long Island.
Old Jan 18, 2001 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You need to either make, buy new, or get a junkyard oil pump drive. It's below the distributor; the distributor gear spins it, and the shaft spins the oil pump. Hook up an electric drill, and spin away! If you have a mechanical oil pressure gauge, you should see the pressure kick in.
It's not enough to just spin the motor with a breaker bar, because you need speed to "build up" oil pressure.
After my car sat for a month totalled, I didn't ever think about priming the oil pump- but I did squirt some regular engine oil into each spark plug hole. Don't know if that helped or not, but it made for one hell of a smoke show! Oh- my valve seals leaked ever since that month of sitting; that was almost 5 years ago.
Old Jan 18, 2001 | 09:14 AM
Dellz's Avatar
Hay Mike My Good friend lives in Babylon li im allways there i love it over there i currently live in old millbasin brooklyn
Dont Race Cops apparently you cant do that! -Dellz
Old Jan 29, 2001 | 12:28 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Anyone else know of anything I should be concerned about? And are there any simple things I can do to make the first start-up easier on the motor?
86 Sport Coupe, 2.8 V6, dead stock, but not for long!
www.geocities.com/camman86
Rock fans click the secret link on my site!
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Thomas
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Dialed_In
Aug 20, 2015 01:45 PM
NBrehm
Aug 5, 2015 07:57 PM
