EGR block off plates? a/c delete? help?
Subscribe
Nov 19, 2015 | 10:48 PM
  #51
Re: EGR block off plates? a/c delete? help?
& it only does it when hot ...& not idling correct
Reply 0
Nov 19, 2015 | 11:16 PM
  #52
Car has no egr valve when at operating temperature it looses power and start hesitating & erratic rpm why is this like this...help
Reply 0
Nov 20, 2015 | 05:34 AM
  #53
What I was saying is EGR will only function when you are at cruising speed, so the fact that you have the EGR deleted will have no impact on your idle.... unless there is a leak in the gasket that was made. You can check that by spraying carb cleaner around it and see if your idle moves. Spray carb cleaner all around the intake gaskets and vacuum lines, there may be a leak or break in a line causing it. Do you have the factory intake or an aftermarket "cold air" intake?
Do you have a check engine light on?
Reply 0
Nov 23, 2015 | 12:59 AM
  #54
Factory intake
Reply 0
Nov 23, 2015 | 01:00 AM
  #55
& no I don't have a check engine light on !
Reply 0
Subscribe
