Should I put a new T.C. with the change of my tranny
Old Jan 31, 2001 | 05:56 PM
91dave's Avatar
Is it really nesasary to do, there is nothing wrong with mine
91 Camaro RS/SS
3.1LTR
Flowmaster Exaust
Hyperchip
K&N Airfilter
Ram Air,Cold Air Induction
Accel Wires,Cap,Rotor,Coil,
Plugs
Low Temp Thermostat
16" 91Z28 Rims, BFGoodrich CompT/A
Pioneer Speakers,Deck
Shift Kit
Power Pullys
Old Jan 31, 2001 | 07:55 PM
will0325's Avatar
its not required that u put a new one, but it is defelately a good idea. do u really wanna pay $700 for a nice tranny to have the vanes in the converter go and take out the converter and pump costing u another $400+ dollars. like i said its not required but a good idea.
Old Jan 31, 2001 | 07:56 PM
20-psi's Avatar
Why do you have to get a new trans? If the old one went bad than there is probably stuff inside the torque convertor. Is the new trans the same as the old one? If not, the TC might not fit.
I would say replace it with a heavy duty one depending on your plans with the car.
Pete
Old Feb 1, 2001 | 09:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm with Pete. Your old TC could be full of metal shavings; you don't want to have those inside your new trans.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 1, 2001 | 12:47 PM
SlowCamaro88SC's Avatar
get a higher stall TC. I have a 3200, and when lay on it, she really moves well, and the launch really it much better.
Old Feb 1, 2001 | 03:23 PM
91dave's Avatar
I lost Drive and overdrive , I dont belive taht there is going to be any metal shavings in the fluid, but if there is I will change it
91 Camaro RS/SS
3.1LTR
Flowmaster Exaust
Hyperchip
K&N Airfilter
Plugs
Low Temp Thermostat
Shift Kit
Power Pullys
Old Feb 2, 2001 | 09:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, it's not so much metal in the fluid as you look at it, but metal stuck inside the torque convertor. You could always cut open your trans filter and unfold it- that's a good way to check for metal.
Reusing the TC's really not a good idea. If you want to, though, there are procedures to flush the torque convertor; they're covered in tranny books. The guys that rebuild torque convertors actually cut them open, clean them, and re-assemble them. Sure your TC might be fine, but for $80 do you want to risk damaging your new trans?
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
