How much draw does an alarm have?
Old Feb 8, 2001 | 10:47 PM
RenoLB8's Avatar
My 'bird won't start again, doing the same stuff as last time. The pattern I see is that I leave it sitting for more then 24 hrs, and then it won't start. The only accessory on in this time is the alarm. I know I'm running at alower voltage then most, because of the underdrive pulleys. Could the alarm be the problem?
-Reno
Old Feb 9, 2001 | 09:41 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
The alarm, assuming it is functioning properly, draws little to nothing from the battery. Is your alternator charging ok? Maybe with the pulleys it ain't putting out enough. Just a thought...
Old Feb 10, 2001 | 11:01 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Im gonan take off the alternator pully its barely even charging and it seems liek i go through batterys like water
deracer
Apr 11, 2016 12:04 AM
1992Z28!
Nov 19, 2015 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gta892000
Sep 16, 2015 12:37 AM
Stauf
Aug 24, 2015 08:31 PM
