mod question
Old Feb 8, 2001 | 04:43 PM
HIX5000's Avatar
mod question
What would happen if I removed the plastic plate thats underneath the airbox? Do you think the air deflector would help push more air into the airbox. Is that plate there to help cool the radiator?
1988 Camaro RS
2.8L five speed
Money pit from hell!!
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Feb 8, 2001 | 05:22 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
I believe it is simply a splash guard...I don't see a reason why you can't remove it. And yes, it would help airflow.
Jason E
'89 Camaro RS 2.8 (Medium Gray Metallic)
Hypertech chip/K&N filters/Accel 8.8 wires, Accel Supercoil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm, Keyless Entry
IROC tailights, tinted windows
"It's for sale"
Looking for: TPI 350 IROC, T/A or GTA
JasonEE98 on AOL IM
Old Feb 9, 2001 | 04:46 AM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Those black things are air silencers (if you own a Camaro). Yes, it does help air flow to remove tehm. Also you can drill up to six 1/2" holes in the bottom to help increase the air flow. When I did this to mine, it pulled a lot harder around 3000 rpm. Very good free mod to do!
Old Feb 9, 2001 | 09:39 AM
Jason E's Avatar
Wait a minute...I know all about the air silencers IN the airbox. I thought what HIX was talking about was the plastic panel, UNDER the airbox...is this what you're referring to HIX?
Jason E
"It's for sale"
JasonEE98 on AOL IM
Old Feb 9, 2001 | 09:55 AM
HIX5000's Avatar
I was talking about the panel under the airbox.
1988 Camaro RS
2.8L five speed
1988 Camaro
2.8L automatic
t-tops
160* THERMO
Rapid fire plugs
Old Feb 10, 2001 | 11:15 AM
HIX5000's Avatar
Wow. I removed the panel and the silencers. Drilled six 1/4 inch holes, there was a noticable difference.
Old Feb 10, 2001 | 04:06 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I just cut the whole bottoms off on mine so the whole filter is exposed
Frozer!!!
Jan 19, 2024 04:55 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
