FWD 60 degree question....
Old Feb 12, 2001 | 09:13 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Where the hell can I get hop up parts for my new car? Other than a K&N drop in, and Accel coil packs (not 100% sure on those), what else can I do?? Anyone make a cold air?? Exhaust? Help!!
Jason E
"The Cruiser"
'89 Camaro RS 2.8
Hypertech chip/K&N filters/Accel 8.8 wires, Accel Supercoil/RapidFires
Eclipse CD and 100x4 amp/Boston plates and 6x9s
Alpine Alarm, Keyless Entry
"It's for sale"
"The Driver"
'95 Grand Am SE 3.1 Coupe
No mods yet...
I'm the only third genner who's daily driver is faster than their third gen!
Old Feb 12, 2001 | 10:15 PM
KED85's Avatar
Put a 3.4 long block under your hood.
No replacement for displacement.
I can't wait to create a CAI package, now.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 12, 2001 | 10:18 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
1800-345-4545 call an get a catalog.. just about anything you can get for a v8 ya can get for our v6's.. or go to your local GM dealership and pick up a GMPP catalog with a full section on 60deg motors, from blocks, to heads, to cams...
Old Feb 13, 2001 | 04:41 AM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Any of the V-8 cat-backs will fit on your 2.8 (same exhaust). I have the Dynamax cat-back on my 2.8 and love it, sounds great. You can make your own cold air induction (just follow the same directions posted in the tech section. Just about anything you can do to a V-8 you can do to the V-6.
89 Camaro RS
2.8 V-6 T-Top Auto OD
ADS SuperChip Street Chip
Removed air silencers opened air boxes
Splitfire Triple Platunum plugs and 8mm Splitfire plug wires
Dynamax cat-back
Old Feb 13, 2001 | 07:13 AM
Ovrclck350's Avatar
I think he's talking about his Grand Am tho.....
Old Feb 13, 2001 | 09:05 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yup, the front wheel drive 2.8, not the f-body one.
That's got the DIS distributorless ignition, right? Visit http://www.bmracing.com and look for their "NuVolt"- it might be under import racers, or new products. It acts like an MSD-5 or Accel 200 box- it boosts the spark output. It's only $120, compared to the MSD DIS-4 which costs $400 or so.
You know about the Accel coil packs...
I hear there's no such thing as a bolt-on cat-back exhaust. I searched a while ago for my friend's old 1987 Pontiac Bonneville- and could not find a system! Either you need one custom-made, or replace just the muffler, or I'm a moron and missed something. That's possible, I didn't search too hard. I'm sure you could give it a universal high-flow catalytic convertor, too.
The heads are the Gen II, aluminum w/splayed valve arrangement- you're ahead of the f-body's 2.8 game already. You might want to give the Crane Magnum 1.52 or 1.60 rockers a shot; but I'm not sure if any machining's required for the aluminum head.
My friend, when he had the Bonneville, was able to get a (I think the name was) "Ractive" intake for the car. It wasn't a cold air; it was a K&N on a stick, but it could probably be "made" into a cold air. Or you can make your own. The Ractive intake gave his car a kick in the butt- altho it did add a bit of that "drone" sound that the ricers have to their cars. (I always thought that noise was 100% exhaust!)
There's also Mantapart at http://www.mantapart.com - they were mainly a "FWD" and "quad 4" site, and not too much of their 2.8/3.1 stuff interchanged with the f-body 2.8/3.1. You might get lucky with them for the Grand Am, tho.
You might also want to check out Clifford, at http://www.cliffordperformance.com/home.htm - last I checked, they were also a FWD 2.8/3.1 business... not too much for the F-body, but they might have something you can use. Summit pointed me to them in '94 when I was looking for 2.8 headers.
I'm sure spoilers and body kits and wheels & lowering stuff is out there, too.
Be wary of a performance timing chain; the 2.8/3.1 timing chains for front-wheel-drive cars are supposed to be 0.1" thinner to fit underneath the narrow timing chain cover.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 13, 2001 | 06:40 PM
Jason E's Avatar
Hehe...yeah, I was talking about the Grand Am
Thanks for all the links Tom...I knew I could count on you to come up with something!! I didn't know about the NuVolt box...I was looking at the MSD DIS box, and had already deemed it WAY too pricey...too much for a driver!! The only reason I got this car was because it was real clean, it was a V6 coupe, and I got it from work for wholesale price. It drives like new though, so I do wanna do some stuff to it.
Its too bad, because it seems like the FWD market begins and ends with W bodies (Grand Prixs, Intrigues, etc). It seems GM compacts get left out of it...time to go digging!
Old Feb 13, 2001 | 08:55 PM
scoob8000's Avatar
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
still same things.. even the DIS packs are available from jegs.. i believe they are around 65 bux per two coil pack.. anything else you can do on a v8 ya can still do.. im guessing you have the second gen motor in it? whats the intake plenum look like? GMPP has several different heads and throttle bodies for newer 60degree motors.. simple thing as even taking the heads to the shop for a valve job.. did that on my 4 banger grandam.. nice little extra climbing hills...
Bubbajones_ya
Jul 6, 2024 08:32 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ironbmt
Sep 27, 2015 06:00 AM
