Head Gasket
Old Feb 12, 2001 | 06:17 PM
Brads RS's Avatar
Head Gasket
I was thinking of porting and polishing the heads on my 92 RS with a 3.1 in it, and I was wondering if any performance magizines had a head gasket that would up my compression ratio from 8.8:1 to 9.0 or 10.0 somthing?
[This message has been edited by Brads RS (edited February 12, 2001).]
Old Feb 12, 2001 | 10:13 PM
KED85's Avatar
If you want real power, slip under the hood a 3.4 long block.
I did.
It pulls like a freight train, now.
Pistons would really make you compression goal, tho. But, at a price.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Feb 13, 2001 | 08:37 AM
Kevin S's Avatar
Most performance mags don't show items for v6's,but thats not to say they don't have it.Just give em a call.
I think it is safe to say....you will probably have to buy them from NAPA or some other auto parts store.If I'm thinking straight they come in different thickness.
[This message has been edited by Kevin S (edited February 13, 2001).]
Old Feb 13, 2001 | 09:09 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could probably have a machine shop shave the heads a hundredth or so, too. If you shave too much off, I hear you need to also shave the intake manifold to match- but the machine shop probably knows how far they can go.
But Kevin's right on the money- no catalog bothers to list 2.8/3.1 f-body parts, since there's not a huge market for 'em. But they do exist, just call! You might also want to hunt down PAW in a car magazine like Hot Rod, and give them a call.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Feb 13, 2001 | 10:57 AM
KED85's Avatar
All I can suggest is call Norhtern Auto Parts
800-831-0884
I checked my SpeedPro book and my Fel Pro book.
I could not find a great chart like they use for the small block Chevy & head gasket thickness.
You're on your own.
Try www.fel-pro.com
or 847-933-9353 (tech line)
Chat Soon,
KED85
Karl
Old Feb 13, 2001 | 01:12 PM
87RS402's Avatar
The only way your going to get the compression up from 8.8 to 9.0 is to mill the heads. If your running the stock gasket then changing will actually lower your comp. The factory uses a steel shim gasket. That type is about .020 thick and aftermarket gaskets run .035 to .040 thick. Your going to have to find a different route, I'd be thinking a 3.4 like KED85 had suggested.
'87 RS 402 Big Block
'92 S-10 Blazer 4X4
'77 3/4T Chevy 4X4 P/U with 500 Cadillac
Qsac
Old Feb 13, 2001 | 07:26 PM
Brads RS's Avatar
Thanks for the info I'll check into some of it. But I think I might just drop in a 3.4 it dosent sound like a bad idea. If I drop a 3.4 in, is every thing gona line up correctly such as motor mounts and such?
Old Feb 13, 2001 | 11:19 PM
KED85's Avatar
Yes.
It's a very detailed but very easy swap.
What you always haveto keep in mind is that what you start with is exactly the same way it must end up looking.
I have made mine look exactly like a 1985 2.8.
It'll pass smog so easy.
Everyone I show it too is so blown away. They cannot tell the difference.
Everything fits, perfectly.
Hardest parts are all the plastic tubes breaking and adjusting the valves. 3.4 valve are very sensitive to overadjusting.
Oh, this thing pulls like a freight train! And I get great gas milage, too.
Chat Soon,
KED85
Karl
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
