Where is VIN number on 60 degree V-6 engine blocks
Old Feb 17, 2001 | 02:11 AM
KED85's Avatar
I heard CA may go to checking VIN number on engine blocks.
Where is it so I may remove it!
When I did my swap, I NEVER saw it at all and I looked.
Only saw casting dates, if that.
Thanks!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited February 17, 2001).]
Old Feb 17, 2001 | 11:31 AM
Johnny Ray's Avatar
Karl, on 3.4L engines this number is found on a pad at the front of the block, just above the water pump. Optional locations for the number are on the lower left side of the engine block, below the exhaust manifold and on the left rear side of the block on a casting to the rear of the manifold.
My thoughts on seeing these identification numbers removed would tend to make me think that the engine had been stolen.
It's up to you if you want to remove them.
Good luck in deciding whatever you do.
1969 Falcon
1992 Artic White Firebird
1997 Black Firebird
Old Feb 17, 2001 | 09:58 PM
KED85's Avatar
Very cool!
I discoverd that the 1985 blocks have the VIN behind driver side exhaust maniold, on a verticle rib, infront of tranny bellhousing area.
These new style exhaust manifold with the 3.4 heat shields cover that area so well!
I'm only letting them think I've got a 1985 block.
Someone isn't going to go thru the effort of checking there.
In fact, I'll take this to the smog guy for a pre-visual check, next week. I'm due around July time, this year.
If I lead him to believe I've got this 1985 car, I bought and it'll need smog soon, do I do anything, now.....he will think by time it comes this summer, he'll omit that detail (that's my car is a legit car).
In CA, they test your gas cap. That part is read by a machine (and determines pass or fail of test, too), numbers on block are not.
Thanks for the 3.4 locations.
Chat Soon,
KED85
Karl
Old Feb 17, 2001 | 11:41 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
karl, i really wouldn't sweat the smog inspection. don't you have a few buddies in the industry??? if i had a clean running V8 under my hood i could just take it to the smog guy at work and say "yes, this is a 3.1L engine " and that's it....visual inspection done.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Feb 17, 2001 | 11:45 PM
KED85's Avatar
Hi Dan,
I pretty much plan on doing that.
I have heard word on the street (last noight at Bob's in Burbank, too) that the smog people now must flunk a certain percentage, to keep license.
Sounds like the cops & their quotas, to me.
Just keeping ahead of the enemy! I worked to hard to be surprised
Chat Soon,
KED85
Karl
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
