drain fuel tank?
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
drain fuel tank?
If I have about 7 gal. of old fuel in my tank and plan on changing my filter,can I just unhook the line at the filter turn the ignition key on and let the fuel pump run that way?Or will the pump not run that way,or is that not safe.If I just unscrew the line without running the motor with the fuel pump fuse out,other than fuel spraying out,won't hurt anything would it?Your opinion counts!
Re: drain fuel tank?
u dont have to drain the tank to change the fuel filter, just unhook the line with the key off and no fuel will spray out of the line
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
For the IROC - there's a schraeder valve on the pass side fuel rail - where you can test fuel pressure at. Put a rag over the valve, press valve stem with phillips screwdriver and release pressure, then change filter.
If the other two cars don't have the schraeder valve, undo gas cap to release pressure.
Regardless, fuel will leak out when you change filter, but not gallons worth - maybe 1/2 cup at most (although it will seem like alot).
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
only fuel past the regulator is kept under pressure, pre regulator pressure is lost soon as the pump is off.
Car: 1992 RS
Engine: Carbed 350
Don't test that theory on a LT1 car! Plenty of pressure on the fuel rail, even after the car has sat overnight! I assumed TPI was the same.
Axle/Gears: 273?277
I want to get all the old gas out before I change the fuel filter.It was messing with my injectors and stinking like paintthiner or somthing when the car was running.I put injector cleaner and seafoam in it,with 5 gallons of gas.But I think I need to empty the tank compleatly of all the old fuel.Put new fuel and seafoam without the injector cleaner.changing the fuel filter was just part of it.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
OP
Once the fuel line is off the filter, the fuel will self siphone out of the tank FAST, drain all you want. It will go till empty.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Gumby, the FPR is on the OUT side of the fuel rail, so the rail will hold pressure when the pump is off.
OP, no, if you want to completely drain the fuel tank, you'll have to drop it. I tried draining mine with the fuel pump and there's still about a gallon or so left in the bottom after the pump started sucking air and getting nothing out of the end of the fuel line in the engine compartment. I haven't finished draining mine yet...
Axle/Gears: 273?277
thats what I was afraid of.Think I'll just do a flush job.Drain all I can,add more gas and drain it again.Maybe 2 or 3 times.then let the seafoam go to work on the rest and see what that dose for it.I droped the tank on the 86 and put a new fuel pump in,just last week.I learned alot.If I do a flush on the 89 I think it will work.If not I will do one of thoughs inside seal jobs. By the was,I got injector cleaner and seafoam both in the gas now.
Car: 82 Z28
Transmission: TH350 for now
Why not just siphon out all you can (via the gas cap) and then top up with new fuel? Seems to be some over thinking here...
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Engine: 2.7L V6
Axle/Gears: 4.41
Fuel tank>Fuel Pump>Fuel Filter>Fuel Rail with injectors>Fuel Pressure Regulator>Fuel Tank. Not hard... "Past" implies "After".
Axle/Gears: 273?277
These things are not all that easy to siphon out.I've taken out my 86 tank and changed the pump on it.Have you ever taken a tank out and sean how there made? You cant even dump 5 gallons out the filler neck!It's true,if ya want all the fuel out ya gota drop the tank and go in through the sending unit hole and mop it out with a rag.You can get most of the fuel out siphoning through the pump hole.
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
So what's the best method here? Just siphon from the tank? Isn't there a ball valve or something in there to prevent you from siphoning?
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
You can pull off the feed fuel line, unhook the fuel pump relay on firewall and jump it together with a wire to start the pump without having car on. You'll use your own fuel pump to extract the contents of the tank. Works best if you have rubber or steel braided lines so you can direct it right into a gas can.
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
