no electrical to anything 85 2.8
Old Apr 3, 2011 | 05:49 PM
firestein's Avatar
Car: 89 T/A
Engine: 5.7
i just cleaned the maf in my 85 2.8 mpfi, and as i predicted the maf sensor needs replacing cleaning didnt make a difference but now after reconecting my battery and everything is back together my engine turned over and died twice and then all my electricals went i switch my ignition over to on and nothing happens the only way i can test my battery is to take a piece of metal with 2 points in my case a pair of plyers and touch one end to the negative terminal and the other end to my a piece of metal, so i did that and it sparked but my terminals are tight and nothing all my fuses are in tact aswell any thoughts help
Old Apr 3, 2011 | 06:48 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: no electrical to anything 85 2.8
Um thats hardly a reliable or accurate method of testing a car battery, just take it to an advanced auto or autozone and theyll test it for you free.
Old Apr 3, 2011 | 06:54 PM
firestein's Avatar
Car: 89 T/A
Engine: 5.7
im from canada so the only place i can take anything to get tested correctly is a dealership i think my local gm dealer offers free diagnostics theyve told me they do but i dont know how well i can believe them, but my car was running then the battery went right after the engine died
Old Apr 4, 2011 | 02:19 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check ALL of the battery cable connections... If the one on the starter is loose, the whole system shuts off. And then check the connection where the smaller wire from the positive cable runs to the junction block behind the pass side headlight, which feeds the ECM, fuel pump, and a bunch of other things.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
usafirebird
Sep 29, 2015 11:58 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
