Car makes a grinding sound when starting and is hard to start
Old Mar 6, 2001 | 04:43 PM
Sweet_85_Bird's Avatar
My car wouldnt start for school this morning.It started about a month ago when i was at school and my car wouldnt start.I finally got it started and it hasnt done it since then except it makes a really bad grinding noise when it cranks up and it turns over forever before it does start.This morning it wouldnt start and it made the grinding sound really bad.I tried to crank it when i got home and it did after about 3 tries.It will start right up when it has been ran awhile and hot.Should i get a new starter and be done with it?
1985 Firechicken
2.8 v6
Mods:
TB Coolant Bypass
My own kik @$$ dual intake
Freshly Painted(bright metallic blue)
Mods to come:
Either an 80 series flows or super turbo dynomax.Cant decide!
An engine is like a person,to scream it has to exhale hard -Flowmaster
Old Mar 6, 2001 | 05:36 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Ya if i remeber correctly it has to do with the solinoid cant remeber what a starter is 75 bux with lifetime warrany at autozone
Old Mar 6, 2001 | 06:07 PM
RenoLB8's Avatar
Get the starter, save yourself a LOT of trouble. Do it ASAP.
-Reno
'88 Firebird LB8
"Cerberus"
"You think you're weak and maybe I'm the cure, but I've got 6 pistons in my engine, and I got one for ya...it's a long shot"
http://www.angelfire.com/il/Firebird28/index.html
Old Mar 7, 2001 | 12:30 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
If you don't do it soon you're going to start eating teeth off your flexplate.. unless you want to replace that, do it ASAP.
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
Old Mar 7, 2001 | 09:27 AM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Lifetime warranty starter from Auto Zone should be only $45...at least mine was.
Jason E
The former third gen...
'89 Camaro RS 2.8
The future third gen...
'87-'92 IROC, GTA or Z28
The driver...
'95 Grand Am SE 3.1 Coupe
Alpine swing face 60x4 CD player
Long Live #3...
Old Mar 7, 2001 | 06:39 PM
KED85's Avatar
Be cheap & lazy.
Remove your starter. I think you have OMITTED the starter shim!
Clean ALL WIRE CONTACTS
Replace the starter in the car. Give it a try.
IF you have not lost the shim that could/should be in there, you may win & save $50 - $75.
Leaking valve cover gaskets really ruin a good starter.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
[This message has been edited by KED85 (edited March 08, 2001).]
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
killer777
Aug 8, 2015 02:47 PM
mustangman65_79
Aug 8, 2015 12:07 PM
