Heater/AC question
Heater/AC question
When I turn my Heater or AC on, the blower dosent work on high. I was wondering if there was some kind of relay that may have went out. Any suggestions would be helpful.
1992 RS
Flowmaster exhaust
Hypertech power chip
180 thermo
Split fire plugs
Crane cams Ignition
K&N filter
1992 RS
Flowmaster exhaust
180 thermo
Split fire plugs
Crane cams Ignition
K&N filter
Mine did this once. Turns out, there was a wire that was shorting out that led to the ECM. When I got it fixed, it turned a lot of things on! I don't know if this is your problem or not, though. Have you recently replaced the blower motor?
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Vman
2.8L V6, 700R4
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
There is a relay for high blower operation. Located in engine compartment next to the blower. If you need a relay to replace it with to see if it's the culprit, you can use the one for your power pull-down hatch (if so equipped).. my PPD relay is currently running my blower since my PPD unit is mechanically fubar.. convenient swapability =P
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
Car: 1986 Firebird
Engine: 2.8 V6
Heh, I just fixed my relay this weekend: https://www.thirdgen.org/messgboard/...ML/001141.html
My GM dealer wanted $22 for it; I'm sure you could get it for $5 at a junkyard.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Thanks for the info everybody. I checked the relay and it turns out that the relay got hot for some reason and melted a hole in the side of it. I'll replace it this weekend and try and figure out why it got hot.
1992 RS
Flowmaster exhaust
180 thermo
Split fire plugs
Crane cams Ignition
K&N filter
1992 RS
Flowmaster exhaust
180 thermo
Split fire plugs
Crane cams Ignition
K&N filter
