could this be the coolant temperature sensor?
Old Mar 24, 2001 | 03:33 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
i was watching shadetree mechanic today, and they brought up a point when changing the coolant temperature sensor. Since the sensor tells the computer if your engine is cold and when its cold it dumps more fuel, then if it was bad it would run rich 24/7. My car does, it constantly runs rich and gets crappy gas mileage...could this be a reason for the problem?
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Mar 24, 2001 | 06:38 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
When mine went bad my exhaust smelt like rotton eggs both times and flooded out my engine with fuel. taked 15 mins to change very easy also change the conector i realsied the connector that was on it even tho it loked good didt have good contct with it.
Old Mar 26, 2001 | 10:15 AM
HIX5000's Avatar
<font face="Verdana, Arial" size="2">Originally posted by FAST RS:
When mine went bad my exhaust smelt like rotton eggs both times and flooded out my engine with fuel. </font>
I noticed that my grand-am(94 3.1L) exhaust smelled like rotton eggs this morning could the coolant temp sensor be bad in it?
Old Mar 26, 2001 | 11:09 AM
FAST RS's Avatar
are you getting any codes. Mine when it was bad it would smell like rotton eggs for a 3 hr drive id come home and itd still smell like it. Give it a shot its only like a 3 dollar part
Old Mar 26, 2001 | 03:56 PM
14 bucks actually... only go with ac-delco stuff. Hey RS, did yours throw a code? mines not...
1989 Firebird
Old Mar 26, 2001 | 05:35 PM
KED85's Avatar
Is it the temp sensor in the driver side cylinder head?
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Old Mar 26, 2001 | 05:37 PM
to tell u the truth..not sure. I think thats the temp sensor actually...i havent looked for it
1989 Firebird
Old Mar 26, 2001 | 06:01 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
the CTS is in the front of the intake manifold right next to the thermostat. it's around $12. when mine was bad it didn't throw a code either. those sensors can be lil bastards sometimes.
Dan
1990 3.1L RS
80 Series Flowmaster
It's fast(er than a 3 cyl metro)
Old Mar 26, 2001 | 06:09 PM
KED85's Avatar
It's that thing?
Try this
Take it out
Go to bench grinder with wire brush on it.
Polish it clean.
Reinstall with pipe thread sealant. See what happens. I did this during my swap. Wish I knew about that IAC item, DAMN!
Chat Soon,
KED85
Karl
Old Mar 27, 2001 | 10:25 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The driver's side cyl head sensor is for the gauge (or idiot light)... that's where my mechanical gauge sender is now.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 27, 2001 | 11:32 AM
FAST RS's Avatar
Mine threw that code fixed that right as i was done fixing that my knck sensor went that sucked.ALl related to my stupid computer goin hada get a tranny everything was frying n it... But the Coolant sensor did brake the plastic housing that the connector goes in broke when i did my thermistat.
Old Mar 27, 2001 | 02:13 PM
superz's Avatar
you say it is runnin rich and smells bad, i'm not sayin it couldn't be the CTS but i would also check the O2 sensor.
Old Mar 27, 2001 | 03:27 PM
Engine: LH0 3.1L
i sure you guys were aware of this, but you know the rotten egg smell is also commonly assosiated with a faulty catalytic convertor. when mine broke, the exhaust at start-up smelled HORRIBLE.
Dan
1990 3.1L RS
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BWilcox
Sep 20, 2015 12:19 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
