i plan to have these mods done by begining to mid of summer.CCS Preformance Chip, underdrive pulleys, Crane Camshaft, crane valve springs, crane roller rockers, Free Flow or no CAT, 160-180 degree thromostat, and i think that is it. What kind of Horsepower do you think i will be pushing, oh yea, i already have Custom Ram air, w/ a K&N filter, and flowmaster Single in Dual out Exhaust. those are the only mods have has as of right now, i'm guessing my HP is about 145-150 right now, any guesses about what it will be if i do all this. thanks.
------------------[*]191(3.1)V6 1992 Pontiac Firebird[*]K&N filter with no air box(open air)[*]bosch patinum spark plugs[*]Flowmaster Exhaust w/ 3" tips[*]Pioneer reciver[*]kenwood 4x6's[*]sony xplod 6x9's[*]1 kenwood 12" powered by a 300 watt jenson amp[*]much more engine and stereo mods to come!!!...., when i get some damn money. www.geocities.com/my_92firebird
Your stock HP and TQ for that year is 140 and 180 respectivly. All those mods should put you in very low 16's or very high 15's. There's a guy on this board with a very very similar setup as you're sugesting and he's running 16.1's with an auto. Here's the breakdown for each mod you're sugesting:
Chip: 5hp
Pullies: 4hp
Cam/Springs/Rockers: 40hp
Exhaust: 6hp
Thermo: 1hp
plus whatever you already have. Just go figure 200 hp at the crank, so about 160 at the rear wheels. Not too bad... I'm also trying to be realistic about the numbers. They could be higher! Correct me if i'm wrong anyone! later...
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Eibach and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"I'm out to seek those pesky VTEC boys!" (don't get me wrong, I'm asian myself! hehe)
Chip: 5hp
Pullies: 4hp
Exhaust: 6hp
Thermo: 1hp
ur gonna be running 18's with all that radio junk in back of your car. Toss it out and its possible to see low 16's
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
92' camaro
Soon to come!!!
Other car;
Hey! I've got that radio and all that junk (and trust me, mine's probably heavier.. 2x10 and 2x4 vertical construction with 3/4" MDF horizontal sheets, well over the 150 lb mark.. the lift kit in my rear is to bring me back to stock ride height) and I run 18's with a leaky cyl and mods barely worth mentioning! I mean.. you'll prolly end up mid 16's with the weight and those mods, so it'll just bring you above stock empty weight performance =P
'86 Camaro SC, black /w silver racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
In search of new v8 engine & transmission, now contemplating t5 swap to get me out of this mess.
MSD coil, Accel 8mm wires, SplitFire plugs, Gabriel hijackers, possible performance chip I don't know about.. gotta crack open the ECM and check sometime
I would hope he is runing better than low 16's.... 16.01 has easly been accomplished without cam, lifters, springs, head work, ect.... Off the top of my head this is my mod list for kncoking on the door of 15's:
MSD Coil
Accel 8.8MM Wires
K&N Conical Setup
B&M Shift Kit
Dynomax Cat back
Catco High Flow Converter
Agh just go to my site http://www.geocities.com/overlift
AntiVTEC
Whats the specs on the Cam?
Quote:
<font face="Verdana, Arial" size="2">
</font>
Is this a reallistic figure or a misprint, if not I know what I am doing this winter...<font face="Verdana, Arial" size="2">
</font>
Nope...thats a true thing. Cam will give about 20, 1.6 rockers and lifters probably 25
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
1989 Firebird
Yep, around 40 or so horses for all those things joe_L. Gotta remember that the things u do to the inside of the motor help a whole lot more than what u can do outside the motor, except a blower and what not. It may be even higher than 40 hp net gain. But the cam and rockers i'm refering to is the crane compucam 2020. Go to cranecams.com and just follow through the site, u'll get to a parts page which shows everything and optional thing u can get with the cam kit. The cam kit (includes the cam, lifters and lube) runs for about 160 at summit. Only problem is installing it! ahh... hehe, payce...
AntiVTEC
40 more HP...
I don't mean to be annoying, but how will the computer in the car deal with this, will resetting it change its diagnostics, or will you need a chip to make up for the differences???(with the cam, springs etc.)
Quote:
<font face="Verdana, Arial" size="2">Only problem is installing it! </font>
I hear you, thanx for the info, I'll go check this all out, I sure could do with <font face="Verdana, Arial" size="2">Only problem is installing it! </font>
40 more HP...
