NEED HELP WITH CODE 35
I have a 1990 camaro RS 3.1L V6. I did a self diagnostic test, trouble code 35 came up
(IAC). can someone plese tell me what I need to do in order to in order to correct this error, also would this also explain why im getting only 8 MPG??
please reply.
THANK YOU FOR YOUR TIME
please reply.
are you talking about the Idle Air Control valve?...if so that des not affect your milage that much, it only sets your idle RPMS...if that is bad the car will idle anywhere from 1k-3500...its a bummer...only a 45 buck part though....but sadly enough unless you car is idleing funny its noy uour prob.
