How does a perfect V6 run, anyways?
Old Apr 6, 2001 | 02:07 PM
87 Firebird's Avatar
I've never really stopped to think about whether or not my engine is running right, but now that I do, it may not be. Does a "perfect" 60*V6 just sit there and purr like newer vehicles, or are they a bit rougher than that? If they're supposed to purr, then something's the matter with my girl, cause she sure don't! What should I look at to correct idle speeds? TIA
Kevin-87 Firebird 2.8 liter A4
!Cat, !Maf, !Air Intake, K&N, Bosch Platinum +4, Blue Streak Cap & Rotor
Performance Rebuild in the planning stages...
Best 0-60 10.26 seconds...for now
Old Apr 6, 2001 | 02:21 PM
v6camaroguy's Avatar
I can't tell you what a new v6 sounds like but I got mine from an old lady who only drove it to work and back and it idles pretty smooth but not like a new car. As far as idle, thats controled by the ecm.
88' CAMARO Sport Coupe
2.8L V6
K&N Air Filter w/RAM AIR
Flomaster
Old Apr 6, 2001 | 03:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My v6 is in pretty good shape, and it's always had a slight lope to it in idle. I attribute that to worn-down cam lobes.. but it's been that way for the past 4 years or so; way before the 213,000 mile mark.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 7, 2001 | 07:50 AM
FBODY-ADDICT's Avatar
My 2.8 used to idle very smoothly, if it wasn't for the slight rumble in the exhaust( random cat, 2 1/4 inch pipe/ flowmaster catback) you couldn't tell the car was on, but just like tom said it's kinda lopey not like the idle on newer engines.
[This message has been edited by FBODY-ADDICT (edited April 07, 2001).]
Old Apr 7, 2001 | 10:47 AM
KED85's Avatar
My 3.4 idles rather smooth.
It pulls atleast 20 inches of vacuum out of gear, at idle & in gear idle is about 17-15 inches.
I use vacuum gauges on all 5 of my cars. It tells alot about the condition of the engine and the gas milage I get.
Yes, I do believe in tachs, also.
This Firebird is getting a full gauge set up, very soon.
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
blackz281le
Jan 11, 2016 07:51 AM
slowsi
Oct 18, 2015 08:49 PM
steimel94
Sep 20, 2015 12:46 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Jk_Under
Sep 8, 2015 08:13 AM
