new to 3rd gen camaro need big help
Old Apr 30, 2011 | 08:26 PM
dogdog130's Avatar
just got my 2nd camaro well it is a 88 2.8 auto well it needed a fuel pump and tank well got both installed andn ow the car will start and rev to 70? then shut off it will stay on if i fluter the gas but soon as i let go it shuts off any ideas
Old Apr 30, 2011 | 11:48 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
Re: new to 3rd gen camaro need big help
I re-read this 3 times and still can't figure out what the car's doing... Anyone else?
Old May 1, 2011 | 12:36 AM
mymonkey562's Avatar
Car: 1992 Z28 G92 L98
Engine: 5.7l
Old May 1, 2011 | 12:46 AM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
best i can see is replaced fuel pump and tank and now it will start rev upto 7000 rpm then shut off unless they keep their foot on the gas pedal so i want to say it sounds like a TPS or timing issue
Old May 1, 2011 | 06:38 AM
dogdog130's Avatar
sorry i was up for 36 hours when i typed that well i replaced the tank and pump and barrery well it starts but will rev to 7000 and shut off if i give it gas it will run till i left off the gas
Old May 1, 2011 | 09:03 AM
ex-x-fire's Avatar
I'd like to help, but you need to use a . or a , once in a while.
Otherwise its just to me.
Old May 1, 2011 | 10:27 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
First off are you getting a check engine light? There could be a number of things causing your problem. You could have a really bad vacuum leak so check all the vacuum lines see if any are broken or disconnected. You could also check the TPS with a digital multi meter, key on engine off it should read .54 volts with the throttle closed and the voltage should climb smoothly as you open the throttle by hand if it jumps around when the throttle isn't moving then you have a bad TPS sensor. Check the IAC valve to see if there is junk clogging the hole where it goes in and spray some carb cleaner to clean it up some if it looks dirty.
dogdog130's Avatar
well if i need grammar help i know who to come to but i need car help smart one
Old May 1, 2011 | 10:45 AM
dogdog130's Avatar
where ic iac valve located
Old May 1, 2011 | 11:25 AM
Car: 1988 camaro
Engine: cammed 3.1
If your looking at the engine from the front of the car its on top left side of the throttle body. It has a square 4 wire connector going to it.
Old May 1, 2011 | 11:48 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Why is it that people still fail to understand the better they word their questions, using proper punctuation an grammar or as close to as possible, the easier it will be to help them.
I'm not sure why you'd be revving, an assumed to be stock, 2.8L to 7000 RPM. They don't really make power beyond 5000 under load and 7000 RPM free revs aren't a very good thing for the engine.
If it's stalling, then there are things to check, like the IAC, closed throttle position, fuel pressure, timing, etc.
Old May 1, 2011 | 10:45 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
+1. How hard is it to form complete sentences and at least sound somewhat intellegent? When you type like a labotomy patient, you're less likley to get good help from anyone.
7K has got to be over redline, no way a TPS could cause the engine to rev that high. Do you have your foot on the gas when your starting it? or are you saying it's reving that high by itself?
Old May 1, 2011 | 11:07 PM
Shadow Z's Avatar
Car: Lots of 'em
ayez i wunt help wit me car but u guys bother me bout grmmer
I'm a bit of a grammar freak myself, but it's kind of annoying to see this thread turn to that. I understood what he said just fine.
He said his oven overheated to 7,000 degrees, and now he needs a new bag of french fries. Also, he said that if he plays his flute, the gas prices go up.
Everyone good now? Alright then.
Old May 1, 2011 | 11:18 PM
Car: 1988 camaro
Engine: cammed 3.1
Shadow Z's Avatar
Car: Lots of 'em
What? Isn't that right?
Old May 2, 2011 | 08:04 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Thanks for the first laugh of the day!
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
reiderz iroc
Aug 13, 2015 04:57 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
