Starting issues
Old May 1, 2011 | 06:21 AM
sshedevil89's Avatar
Starting issues
I have had my 89 V6 since brand new...in 95, I put an obnoxious stereo in it and have had start and power issues ever since. Here I go again...new battery...heavy duty and higher power alternator already checked and replaced recently. Wanted to drive it yesterday and it would not start...got any ideas? Getting frustrated..
Old May 1, 2011 | 10:33 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Starting issues
By no start do you mean its not turning over or your battery drains? Don't get frustrated third gens have their own personality they like to give you little issues to see if you love em enough to fix em
Old May 1, 2011 | 10:41 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Starting issues
Originally Posted by sshedevil89
I put an obnoxious stereo in it and have had start and power issues ever since. .
As a rule, in this case and life in general, if you do something and things get worse, undo what you did, figure out why it was worse and start again. Otherwise you'll always be fighting what is fundamentally wrong.
Old May 1, 2011 | 10:02 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Starting issues
Key words in the OP are "obnoxious stereo"...
When you do any sort of stereo upgrade, you're supposed to upgrade a couple of wires as well, not just throw a new alternator and such in and call it a day. Upgrade the alternator to battery wire, the engine ground strap, and the battery to body ground. Remove the wire from the back of the alternator that runs to the junction block behind the pass side headlight and replace it with a wire running straight to the battery positive terminal. I used 8 gauge wire for all 3 wires.
Could also be that the amplifier or headunit isn't completely shutting off or is shorted and continuously draining the battery... Try removing the amp's inline fuse (between the batt and the amp) for a couple of days to find out. If there isn't an inline fuse, you NEED to add one.
Old May 1, 2011 | 11:24 PM
Car: 1988 camaro
Engine: cammed 3.1
Re: Starting issues
That is true when I first put an amp for 2 12's it killed my alternator for some reason in my old car. That reminds me I got to do the big 3 upgrade on my car. For some reason I'm thinking the op's remote wire may be getting power at all times leaving the amp on to drain the battery.
Old May 1, 2011 | 11:26 PM
Shadow Z's Avatar
Car: Lots of 'em
Re: Starting issues
Just take the dumb radio out. Problem solved.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
