2.8 Timing woes...
Old Apr 9, 2001 | 06:02 PM
87 Firebird's Avatar
2.8 Timing woes...
Today I reset the timing on my 2.8 to 12 degrees. I then took the bird out and did two 0-60 runs. Both were over 15 seconds. Needless to say, I wasn't very happy. This thing had ZERO torque. Could the engine have started knocking as a result of the bumped timing and the computer is now dropping timing to compensate? Would resetting the ECM have any effect on the problem? TIA
Kevin-87 Firebird 2.8 liter A4
!Cat, !Maf, !Air Intake, K&N, Bosch Platinum +4, Blue Streak Cap & Rotor
Performance Rebuild in the planning stages...
Best 0-60 10.26 seconds...for now
Old Apr 9, 2001 | 08:02 PM
KED85's Avatar
I know when I did my first timing chain swap, I had the old block. It was worn.
But, the new chain made it live!
But for power, I cranked the timing off the reading (about 20 or so).
Putting it at stock, sucked big time. So back I went to the higher number.
It didn't ping, it died, as I drove up a hill, without the bottom water hose attached!
That's why I did the 3.4 swap.
I also checked timing by timing, proper way. Then I said, screw this and did by ear & driving.
The result was the same higher timing was the answer.
IT COULD also be a bad MAS, as that controls timing, too! Atleast it did with my 1985 Bird
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
86Base
Aug 8, 2015 01:34 PM
