Code 32
Old May 2, 2011 | 09:45 PM
z2886camaro's Avatar
Code 32
so i hv a 87 2.8 v6 and the check engine light comes on and i checked the code and it comes back with code 32 which i searched on here and it says Fault in barometric pressure sensor circuit OR Fault in exhaust gas recirculation valve diagnostic switch OR Fault in electronic vacuum regulator valve
just wondering what i should start with or how to test these
thanks alot
Old May 7, 2011 | 08:17 AM
Re: Code 32
just bumping this and realized i didnt say what its symptoms are. It has some trouble starting up and has a bit of a rough idle untill i hit the gas once. Also the first time i hit the gas to move the car hesitates alot. i just did a full tuneup so all that is good. so the only thing would be the code coming up and i was gonna change my fuel filter and put some injector cleaner in it.
Old May 7, 2011 | 12:24 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Code 32
There's a box with a 4-wire connector next to the ignition coil... Disconnect it and see if the running problems go away. If not, the box and the EGR solenoid may be shot or the EGR valve needs to be cleaned as it's stuck open. There is no BARO sensor on the fuel injected 2.8.
Old May 8, 2011 | 03:29 PM
Re: Code 32
ok thanks ill try that
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
