rear end swap??? again...
Old May 8, 2011 | 03:30 PM
mikeal8208's Avatar
Car: 1991 camaro RS
Engine: 3.4-3500 hybrid + Vortech V1 S-trim
Axle/Gears: 4.11 soon
What's stronger a 3.4 rear end out of a 1993 rpo code I believe to be a AU5 vs the 1986 2.8 v6 That I have in the car? GR difference is a 3.23 in the newer one and 3.42 in the older one...
Old May 8, 2011 | 03:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: rear end swap??? again...
the 93 rear will have 28 spline axles, other than that, no different in strength. but the 92 rear is wider.
Old May 8, 2011 | 03:57 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 86 will have 26-spline axles, the 93 28 spline. Check the 10-Bolt FAQ for more info.
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
