ignition upgrade
Old Apr 10, 2001 | 04:24 PM
Brads RS's Avatar
ignition upgrade
I got a 92 3.1 rs and I was thinking of getting an ignition amp and coil. What brand does everyone recomend and which one gives you the most bang for your buck. Also how much of a difference should i expect to feel if any, in hp and tourque
1992 RS
Flowmaster exhaust
Hypertech power chip
180 thermo
Split fire plugs
K&N filter
[This message has been edited by Brads RS (edited April 10, 2001).]
Old Apr 10, 2001 | 06:02 PM
RenoLB8's Avatar
First, I would suggest underdrive pulleys, and something more dramatic for your intake, but if you're bent on Ignition, I'm personally a big fan of Accel.
I run an Accel 300+ multi-spark with Accel remote mount coil, Accel 8mm wires, Accel cap and rotor, and spiltfire plugs. Up until a few days ago, this combo kicked ****.
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
http://www.angelfire.com/il/Firebird28/index.html
Old Apr 10, 2001 | 07:13 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Do pullys biggest improvemt out od all the modes ive done and saves you gas =) But also i like MSD but on my next car hopefuly that 68 firebird im gonna try mallory just to have a different setup. but MSD is good quality. I herd Accel has gone down in quality
Old Apr 10, 2001 | 08:41 PM
Brads RS's Avatar
I heard that the under drive pullys drop your voltage at low rpms, is this true? cus I though about getin em but im running fog lights and a pretty good size sound system
1992 RS
Flowmaster exhaust
180 thermo
Split fire plugs
K&N filter
Old Apr 11, 2001 | 06:43 AM
Brian K's Avatar
I have the Accel 8.8MM Wires, MSD Coil, and Accel Ignition Box... The Coil I noticed the car pulled harder and faster, but the Box I did not notice...
Old Apr 11, 2001 | 09:33 AM
KED85's Avatar
I use the 8.8 Accel.
It made no difference, as the previous plug wires were basically new & good.
I use the Accel remote mounted coil.
THAT'S GREAT.
The BEST bang for buck, is rebuild your current distributor, put in all new electronics. Then go forward with the goodies.
If your plug wires are still good, leave them.
After you do the ignition goodies, then you can use cheap plugs again. I use $.99 ones or $.79 ones. Actually, with the swap I did, I media blasted the old autolites and reused them!
The hi spark ignition system, will now ignite any plug, to its peak performance.
Rebuild the distributor is the best effort.
Adding anything and having a weak link under the cap is inviting trouble. Those electronic little parts do not last forever.
Reno,
tell me you've got success!!
I'm rooting for ya!!
Chat Soon,
KED85
Karl
1985 Firebird 2.8 to 3.4 swap project for Smog Happy LA, CA
seiplentz
Aug 19, 2019 06:02 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Jlanz55
Sep 6, 2015 02:35 PM
