Lazy camaro..ˇ :/
Old May 6, 2011 | 11:07 AM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
Lazy camaro..ˇ :/
I just fixed my camaro 92... change the fuel pump, ignition spark system and the fuel inyectors.. and startsˇˇˇ...
but sometimes when i got it started it just shuts off when i change to drive or reverse if i dont push the accelerator..
In the streets the car feels so lazy.... i can hear the motor running fast but i got no such speed....
Could be fuel pressure? fuel lines? TPS? Transimission???
Thank youˇ
Old May 6, 2011 | 11:51 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Lazy camaro..ˇ :/
Sounds like a vacuum leak to me, idling high, yet stalling out+low power.
Old May 7, 2011 | 07:35 PM
fitojdj's Avatar
thanks for answer... (:
a friend said the same....
when i used the car yesterday, it worked perfectly during the first 5 minutes, went up to 80 mph without problem, but when I go down the speed begins to get lazy again, then stop and do not keep the engine running more than 2 seconds ... and then it worked fine again... and now the car shuts down if i dont keep accelerating.... like the begin.. also throws smoke sometimes....
http://dimex.comoj.com/camaro_92_fail.mp3
that is a mp3 of the camaro failing... less than 1 mb
tglennon11
Sep 23, 2015 05:30 PM
Reno
Nov 16, 2001 11:23 AM
Rob P
Nov 6, 2001 06:51 AM
Mister MOPAR
Jun 6, 2001 06:04 PM
90IROCK
Oct 23, 2000 01:34 PM
