85 Camaro 2.8 turns off in reverse and drive help
Old Feb 22, 2011 | 07:14 PM
85blkmaro's Avatar
Car: 85 Camaro Berlinetta
Engine: 2.8 V6
Axle/Gears: stock
Just got my 85 Camaro 2.8 rebuild with new pistons crank shaft performance cam so i went to the shop to pick up my car i was about drive off home when all of a suden when i put in drive it turns off or in reverse only way i could get it to drive is if i put it in nutral and give it a lil bit of gas and pop in drive the mechanic said it could be my torque converte thats locks up so i took it to a transmission shop and they said it not the tranny its the motor has anyone had this problem what should i be looking for and also when i start the car blue smoke comes out
Old Feb 22, 2011 | 07:35 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 85 Camaro 2.8 turns off in reverse and drive help
Sounds to me as if it was rebuilt, the shop who did the rebuild didn't do a good job... If the smoke happens only on startup and not full-time (like I would expect with some lube in the cylinders), then you probably have valve sealing problems, or the rings may still need to be broken in (probably the valves, though). You'll need to check for trouble codes from the ECM before going any further, but I would definitely talk to the shop who did the rebuild to find out what they did that the engine is burning oil...
Old Feb 23, 2011 | 12:50 PM
84CAMARO28inFL's Avatar
Does the smoke come put as a "Puff" and float away in the shape of a balloon? Mine does that sometimes> We suspect Oil gettign through. Hopefully it "fixes itself" with good, sealing Oil.
Old Feb 23, 2011 | 03:15 PM
85blkmaro's Avatar
Engine: 2.8 V6
Axle/Gears: stock
Where Is that EMC located on the car? And is that expesive to replace? Also they told me that it could be my idle control that could be bad also and the blue smoke goes away when the car is idling but the and when i rev it a bit the motor strugles to rev up like
Old May 7, 2011 | 10:38 PM
fitojdj's Avatar
Car: Camaro RS 1992 25th
Engine: 3.1 L 191 cid LH0 60° Gen II V6
Transmission: Automatic
Axle/Gears: Heritage Package (RPO Z03)
Check ur tps, ignition system or maybe an injector went bad....
Old May 7, 2011 | 10:39 PM
fitojdj's Avatar
EMC its down the passager dashboard
specialized
Jun 18, 2022 09:26 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
