fuel line
Old Apr 22, 2001 | 10:07 PM
v6-3.1's Avatar
fuel line
how can I tell that I have a fuel leak, the self diagnostic shows no codes except for 35(IAC), that cant be the cause for 8 miles per gallon. Its gotta be something else. I did a tune up (every thing except for the distributor cap). could the ignition timing be the problem, please tell me the possible causes so that I can check them?
Old Apr 23, 2001 | 09:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
An internal leak, as in, leaking injectors? You'd need a fuel pressure gauge for that.. they're about $40-$50; you need the high pressure one (0-100 psi). The low pressure ones are only good for carbureted and TBI injected engines; -not- MPFI or TPI.
Ignition timing's part of the tuneup procedure; it could definately have an impact on both power & economy, as well as the dist. cap.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
