HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!
Old May 12, 2011 | 02:58 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
In my seemingly never ending quest to a) improve my 3.1 and b) put together the most beautiful V6 engine bay EVER, I have been trying to figure out a way to improve the airflow without attracting the attention of the smog police here in California. Having gasket matched my intake and polished it, I was still frustrated by that sharp bend the airflow has to make to get from the upper to middle plenum manifold, when I suddenly had a revelation and came up with THIS!
HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!-100_1141.jpg
These spacers straighten the airflow and ease the transition between the two manifolds, so here is the entire setup, less the middle manifold already installed. * the top part is my hand made coil bracket, complete with 'bowtie' cutout!
HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!-100_1142.jpg
Here is a shot of it installed (the ignition wire looms are another mod of mine too).
HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!-100_1136.jpg
These are prototypes, but I am willing to sell them as a kit if anyone is interested. The cost will depend on how many orders I can put together, since the CNC initial setup is expensive, so the more folks that want them, the better. Given that this was a first time prototype, how did it work? FREAKIN' AWESOME!! I have not flowbenched them yet, but the car seems- and this will sound strange- LIGHTER. It just gets up and goes quicker, as it it can finally BREATH.
These are 1/2 inch 6061 billet aluminum. At this thickness, the manifold still clears my STB by 1/4 inch. Without the STB, I can run 1 inch spacers and still clear the hood.
If anyone is interested in this ridiculously simple, effective mod, let me know. Keep in mind that I polished these (wetsanded up to 1500 grit them Mother's polished) to match my intake. It makes more economic sense if you want some to get them raw, so you can polish, powdercoat or anodize them to your needs(I may end up anodizing mine red to accent them, but NOT until I pass smog in September!).
Let me know what you think!
*patent pending
Old May 12, 2011 | 03:03 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Re: HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!
*Looks like the computer shuffled the photos- sorry about that!! But you get the idea.
Here is a shot from the other side, showing my custom coil mount...
HERE IT IS!! The easiest, BEST mod I have EVER done to my intake!!-100_1143.jpg
Old May 12, 2011 | 03:05 PM
FirebirdDude88's Avatar
Car: 88 Firebird formula clone
Engine: Yeah its in there
Transmission: Thats in there too
Axle/Gears: Yeah there in the back
im interested. how much to make 1?
Old May 12, 2011 | 03:12 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Really, I need to hit 25 sets to make it financially viable. Let's give it some time and see how many folks are interested. And they don't have to all be the same size either- once the machine is set up, I can cut 1/2 inch OR 1 inch, it doesn't matter.
Old May 12, 2011 | 03:13 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
That was going to be my first question! Do you know the part number on the stb? I am looking for one that clears the TB. I want a 3 point brace. And what's the price range on the spacers likely to be?
Old May 12, 2011 | 03:16 PM
okay. well count me in! and if 25 people dont want it, then let me know how you did it because i have a friend who is a machinist
Old May 12, 2011 | 03:27 PM
project89's Avatar
ive done this before it helps out a lil bit, but if u want to get really tick with them have them drilled for direct port nitrous nozzles if somone dosent wat to use nitrous
1/8 inch npt pipe plugs will block the nitrous nozzle holes
Old May 12, 2011 | 03:32 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I thought about the nitrous setup, but I was looking at a streetable setup that wouldn't get me arrested!
Old May 12, 2011 | 03:58 PM
project89's Avatar
nitrous wont get u arested u just need to hve the bottle unhooked on the street or get smart and have a lil 5# pound bottle in p lain view with the line disconected.
then stuff a 10# bottle in the spare tire well( the real nitrous bottle ) and u can leave that hooked up ,cops stop u and see the first empty bottle unhooked they wont bother looking for another and ur in the clear
i do belive the lowest u can go with the direct port system was 100 or 150 nitrous shot though
Old May 12, 2011 | 04:24 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
I don't suppose you could get dyno numbers.....
I'm in if it works.
Old May 12, 2011 | 04:30 PM
project89's Avatar
I'm in if it works.
i can vouch for this mod used to run it on my turbo 2.8 and 3.1 when i used the stock upper manifold
Old May 12, 2011 | 04:43 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
That looks really cool. I've thought about how the air has that sharp turn to make before, and this looks like a good solution. I'd be interested in knowing how much of a difference this would make power-wise.
Do the TB coolant lines still reach ok?
If you can make em for under $100 a piece then I'd be in!
Old May 12, 2011 | 04:57 PM
project89's Avatar
Attachment 219153
Attachment 219154
Attachment 219152
*patent pending
psst talk to firstfirebird instead of whoever ur using to machine them
Old May 12, 2011 | 05:00 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
i'm interested if it makes a difference
give us a rough idea of cost
Old May 12, 2011 | 05:11 PM
project89's Avatar
if he talks to jon im pretty sure it will be cheap,
Old May 12, 2011 | 05:23 PM
58mark's Avatar
it's nice to see a 3.1 plenum all polished up like that. I'd never seen one that nice. I thought about getting one like that and replacing my 2.8 plenum (when and if I ever upgrade to a 3.4, but now I think I'll just find a chevy bowtie emblem to put over the 2.8.
Old May 12, 2011 | 05:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Make them out of pheonlic plastic, will lower the cost 2/3s, found most places that sell big sheet, will do deals on scraps that will just end up in the trash big enough to make small items like that, also stops heat transfer and looks like a reg gasket.
not sure a highly polished spacer won't grab attention by someone who looks at engines all day long looking for flaws, they would expect to see a dark colored gasket.
Old May 12, 2011 | 05:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I got one half done done / preped for polish I might let lose.
Already spent a few hours filing and sanding down all the casting marks.
Old May 12, 2011 | 05:55 PM
gumby has the right idea
Old May 12, 2011 | 06:09 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
As an ex-CNC machinist, I can say that using multiple scraps is not the way to go, if your looking at the lowest machine time cost.
Cutting 25 out of 1 large plate costs less setup time than cutting 25 out of 25 smaller plates. Or 5 out of smaller plates, etc. Setting X,Y, Z on each piece if they are not all matching would cost more than the cost by just buying 1 large sheet.
Old May 12, 2011 | 06:24 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
don't need a CNC to use plastic, a jig saw, a scroll saw, small hole saw, files, any number of ways as it cuts easy.
spare set of intake gasket n a lazy weekend, most anyone could make a set.
A drill press and a cross slide vice can also make things easier.
The original CNC. [HF sells a nice cheap cross slide]
Old May 13, 2011 | 12:54 AM
mars061's Avatar
Car: 87 IROCZ Z28
Engine: 3900V6 GT4088 intecooled
Transmission: TH350
Axle/Gears: 3.45 MSF Spool
Yeah would be better out of phenolic, seen ppl make them with a cutting board, that thick white plastic stuff...
I can't see these making any more power than stock though. Likely lose some top end with the longer runners.
Old May 13, 2011 | 10:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
How many high speed run do you do a year that an extra 1/2in of runner length is gonna matter???
ever more of a mute point with the speed limiter on most of the line.
Old May 13, 2011 | 10:58 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
This is pretty cool, if you talk to some fiero guys on fiero forums you would more than likely get more interest as many have the 2.8 v6 in there and the spacers would work in there. Did you have to mod anything to fit the STB in there?
Old May 13, 2011 | 11:14 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
There was one additional spacer needed to elevate the throttle body cable bracket a corresponding amount so it bolts to the top plenum as before, but other than that- straight bolt on. Misses the STB by about a 1/4 inch!
I also don't have the TB coolant lines hooked up, so that was not an issue. In fact, I removed the whole coolant tube assembly from the bottom of the TB. It is just 4 Torx screws I think...
And as to any drop off in top end: it is a V6, not an LSX! And I live in California, so I am lucky to get over 75 mph at any time...
Old May 13, 2011 | 01:15 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
I don't mean you'll lose top speed, I mean you'll lose power at the top of the powerband. It will make peak HP lower into the RPM range. The intake runners are already too long for a car (this engine was designed for pickup trucks). So you just made the already too long runners even longer.
Old May 13, 2011 | 03:05 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
I'd take a set, PM me if you are making them.
Old May 13, 2011 | 03:48 PM
project89's Avatar
lol bring the car over to utah and it will leave with about an extra 120 hp
Old May 13, 2011 | 05:49 PM
thizzlamich's Avatar
Car: 88 Chev Camaro
Engine: L05 V8 from 93 Caprice Interceptor
Transmission: 4l60 Auto
Axle/Gears: Stock ones limited slip i believe
man if these are proven i'd be down for a set as well
Old May 13, 2011 | 11:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
and which range is that? according to most they don't make any power over 4500 [cause its a truck engine], yet simple breathing mods to one like mine and it pulls hard all the way to redline and ask for more. so ill only be able to red line it then you say? oh the shame
Old May 14, 2011 | 12:33 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I'm in, if you can come to Az and install for me!
Old May 14, 2011 | 03:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I had a set of 1/4 spacers identical to this on my car years ago. Maybe the 1/4" just wasn't enough... I ended up making them into flanges for my sheet metal upper intake.
Old May 15, 2011 | 01:36 AM
Joecat's Avatar
Engine: 2.8L V6
Transmission: 7004r
I would also be interested.
Old May 15, 2011 | 09:31 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Wake up and smell the wiped cam lobes. Any 60v6 can rev to 6K, it takes real port flow to make power up there. Simply extending the runner length is not going to do that. IIRC a iron head 3.1 makes like 60 HP @ 6K RPM
It's been proven for years that things like this do not improve power. They shift the power band lower by increasing runner length. The only benefit to adding spacers like this is for direct port nitrous. I'll spoil something else for you guys too.. Phenolic spacers are usually worthless as well.
That being said.. drill/tap them for nitrous nozzles and you could have a pretty neat setup for a stock engine.
Old May 15, 2011 | 09:44 AM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Wouldnt the power band being lower be better for city driving because of torque coming faster? I didnt ask that question well, but I hope its understandable.
Old May 15, 2011 | 10:07 AM
Engine: 450HP 355
Transmission: TH350
Yes, it could be felt as that.
With such a small increase in runner length it won't change by more than a few hundred RPM's. More of a placebo effect than anything.
Old May 15, 2011 | 10:48 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Why so searious, Im trying to screw with him to see what he says.
And all I can say is, it doesn't take allot of work to make power up top, just have to open thing up so it can breathe. besides all the goofy stock air ducting, allot of it lies in the exhaust. A straigth shotgun like exhaust is very important. 1 simple 90* turn out is all it took to totally kill all my top end power.
Old May 15, 2011 | 03:52 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I am sure some, like Gumby, will 'poo poo' the whole idea- and the effect may be negligible, by my car seems to be more responsive and less asthmatic with this mod.
Old May 16, 2011 | 03:55 PM
mars061's Avatar
Car: 87 IROCZ Z28
Transmission: TH350
I think you're kind of a douchebag. I don't like you.
Old May 16, 2011 | 04:17 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Oh snap.
Old May 16, 2011 | 06:42 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
If you are interested for sure, send me a PM with what thickness, 1/2 or 1 inch, you would want. I can then figure out a price for everyone. IF YOU WANT IT DRILLED FOR NITROUS FITTINGS, GOD HELP US, mention that too. I can drill it for the fittings for a 'stealth' setup so that it isn't visible in a cursory inspection. It will cost more though...By the way, the vacuum lines and cables all fit fine- the only other mod necessary is a corresponding spacer(I will include that too!) and a longer bolt for the throttle body cable bracket that bolts to the middle plenum. You have to raise that so that the upper part bolts to the top plenum as before.
Old May 16, 2011 | 07:51 PM
  #42
Car: 91 Camaro
unless you are machining them yourself, I'd suggest looking into having them cut on a water jet. might be cheaper.
Old May 16, 2011 | 10:45 PM
  #43
Engine: 450HP 355
Transmission: TH350
Gumby, i just prefer to see correct factual information posted.
When people post things like "OMG, I just did xxx and gained xxx power!" with out a shred of actual proof (and against the logic of how engines work), it reflects poorly on the community.
People who don't know any better buy into it then you have a bunch of 2.8 stock iron head engines with Comp 2030 cams, Truleo intakes and shorty headers running around thinking V6's suck because they can't run any faster than a 15.0.
Old May 16, 2011 | 10:56 PM
  #44
Car: 1991 Firebird
^I'd love a 15 flat.
Old May 17, 2011 | 07:32 PM
  #45
Car: 91 Camaro
14.97 minus the Truleo.
Old May 17, 2011 | 07:41 PM
  #46
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
add nnnaaawwwzzz itll give you the same as the truleo
Old May 20, 2011 | 01:58 PM
  #47
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Pricing available at last!! If you have not already, send me a PM and I will get you a quote!
Old Oct 4, 2011 | 06:09 AM
  #48
crazybird's Avatar
Car: 1987 firebird
what is the performance gain? and how much?
Old Oct 11, 2011 | 08:43 AM
  #49
confucius101's Avatar
what ever happened with these??? lol
Old Oct 11, 2011 | 06:04 PM
  #50
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have been away for a while- trying to track down a replacement since my car burned to the ground... send me a PM if you are interested in some.
